I'm in the middle of adjusting the gear cables. No spare pinch bolts so the bungy method will have to wait.
It is currently hard to select a gear, especially downshifting......likely the gear cable adjustment, maybe also the new clutch cable needs readjustment.
Anyhoo, amidst all this, I noticed my gear selector grip can rotate right around, while the bike is stationary in neutral, not going. Not the metal piece with the clutch lever, just the rubber grip. I can't recall if this is normal, or have I broken something while trying to force a shift
