I mentioned the Rotax embroglio, not because their engines are in any way similar to Vespa, but how the battle royal and myths about TCW-3 began. An issue pertaining to one manufacturer's actions pertaining to a particular line of engines broadened out across the whole 2T world. Most likely because the average self appointed "expert" really has no idea about what lubricant standards really are intended to do.
The difference in performance between API TC and NMMA TCW-3 in an air cooled 2T engine has not been "quantified" simply because the two standards are tested at different operating conditions in two different types of engines. Sort of like the reason diesel or jet fuel does not have an octane rating. API TC requires testing in a 50cc and 350cc air cooled 2T for (1) anti-scuff characteristics, (2) piston ring sticking and engine cleanliness, and (3) pre-ignition. If an NMMA TCW-3 oil passed this test, it could be rated API TC/ TCW-3. Simple fact is that few, if any (NMMA) TCW-3 oils have been labeled to have passed API-TC standards. That's a simple "pass/fail" test. It either performs within the limits or it doesn't. Of course, the lack of labeling could simply be because they never tested the oil to TCW-3 standards, but there is no way of knowing for a particular oil. What is known is that several TCW-3 oils have been tested to API TC standards and have failed.
The same goes for 30W ND. It does not pass one or more of the anti-scuff, ring sticking, engine and/or pre-ignition cleanliness standards of API TC.
API TC is not a destructive test. It's a normal operating limits test. You run the engine through the test profile with a given lubricant. If the scuffing, ring sticking and deposits and pre-ignition are at or below the maximum level of the standard, the oil passes. If any of those limits are exceeded (doesn't matter by how much) the oil is not API TC. Nor did API ever attempt to say at what point scuff, ring sticking, deposits or pre-ignition are "damaging". Rather, a level was identified consistent with proper engine performance and long life.
Now, if you set 30W motor oil as your performance standard, then that's a different story. Both API TC and NMMA TCW-3 do a "better" job in any type of 2T engine.
As I said, all three "work". The issue is which standard is "optimal" or at least tested in a manner directly relevant to providing an industry accepted level of protection. Besides the science and chemistry not supporting TCW-3 being optimal for an air cooled 2T, a rating of TCW-3 is not based on testing in an air cooled engine, nor to operating conditions of the typical air cooled engine. Kinda like applying Rotax to Vespa, to use your words above.
Trumpyscooter is spot on:
ive seen this movie before, it has a really boring ending
People often base their evaluation of whether an oil "works" or not on their evaluation of their engine in isolation from established lab tests and standards. That's fine. But if your engine doesn't fail or end up too crappy for your view, that does not in any way refute lab standards and analysis, nor make the standards a "myth".
In the long run, it's what makes you happy that matters. API and NMMA on the other hand, simply establish and enforce standards, and are not in the business of being happy - just accurate.
Your OP asked if TCW-3 "was in any way bad". Based on standards, there is no way to tell. The standards for TCW-3 do not address an air cooled, non-marine application. The standards for API TC do. Standards are "pass/fail", not "bad, good, better, best". All that can be said is that TCW-3 is not subjected to a "pass/fail" standard for our type of application. Feel free to decide whether that is "good" or "bad" in your view. I simply offer that based on the chemistry and standards, it is not "optimal".
