@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
right me high n low idiot lights have stopped working so that means me speedo dont light up for night .... its somewhere in the loom as ive tested the speedo n thats all good ....
does anyone know which wires in the plug do the high n low beam n how i can easily test em ???
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
duracell bunny
nobody???? i riding in the dark with no lights on me speedo
@joep avatar
05 PX, 80P200, 63Li150, to many others
@joep avatar
are you sure it's not a burnt out bulb? Do you have a meter to test it? Check and see if your getting power to the bulb, if you are and the bulb is not burnt out then you have a bad ground. If you're not getting power to the bulb find a hot line in the head set and jump it off that.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
again
its not a bulb ...... they all work n so does the speedo..... I tested it with a 9v battery ...... I wanna test the wires in the loom ... I have a multimeter but it might as well be a helicopter .... fuck knows how it works
@sara_alexandra avatar
PX232 Lambretta li s3, Vespa cross, Vespa cross prototype, Honda NS400r....
Re: duracell bunny
i like the dark
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
not mine
me too but speed cameras and a speedo I cant see
@vader19 avatar
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
@vader19 avatar
Re: again
Come on B.. google that shit.. it's on Youtube... if you can at least find the continuity position on the meter, you can test the bulbs, you can test the wires going to the bulbs.. and you can figure out if you have a broken wire, blown bulb etc.. it's really easy.. (at lest the simple functions I use) Trust me, I was an electrical idiot.. I've moved up to simpleton, and still moving up the ladder and I owe it all to the multimeter! (and a little BlackBart )
@joep avatar
@joep avatar
https://nationalvetcontent.edu.au/alfresco/d/d/workspace/SpacesStore/4e1e0e97-bc55-4c44-a692-4d31f4d0d934/13_02/content_sections/learn_about/05_testing_page_001.htm
Learn how to use your meter, it will save you a lot of trouble.
Switch it to continuity mode. Touch the test leads together, you should hear a beep or high pitch noise. This tells you that you have continuity, now touch the a test lead to each end of the bulb and if it makes a sound the bulb is good, if not the bulb is bad.
If you are running a battery you want to test wires (while scoot is running) with the meter switched to DC.
If you do not run a battery you would test in AC.
It will read between 12 and 14 volts if you are getting juice.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
meat market
cheerz.... im gonna have a hunt through youtube in a bit then
GTS 250ie "gone" & others vintage
Download wiring diagram on scooterhelp.com.
[ Time: 0.0109s ][ Queries: 3 (0.0030s) ][ live ][ 343 ][ ThingOne ]
