GTS 125
GTS 125
Ok, so I 'plugged' and it now 'plays' but probably a bit too much! On my Vespa GTS 125 I insert the key and it does not disarm the alarm, just the key fob does that. Is this right?
GTS 125
GTS 125
Re: Vespa Plug & Play Alarm advice needed
Anyone can help?
@ckaiserca avatar
@ckaiserca avatar
If the alarm is anything like the one for a 300, then the fob is the arm/disarm. Inserting your key in the ignition and turning it on will cause the alarm to go off. This is by design.
My OEM alarm for my GTV has a fob and a small "key" that fits into a port attached to my left knee pad. The "key" will arm/disarm the alarm if you lose the fob or the battery in the fob happens to die.
⚠️ Last edited by ckaiserca on UTC; edited 1 time
That sounds right. If the key got into the wrong hands, the scoot would still be alarmed. Of course, many folk keep their alarm fob and car/bike key on the same key-ring, which is a bit daft security-wise although more convenient.
[ Time: 0.0102s ][ Queries: 3 (0.0021s) ][ live ][ 343 ][ ThingOne ]
