Vespa LX 150
Vespa LX 150
Can someone comment on the effect of an engine oil leak ?
Reduced compression? Heat? How can i fix this leak?[/img]
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
Can you see from above where it's coming from? Clean it all up and then look again after a ride maybe. When I had a leak I couldn't find the cause myself so took it to the bike shop to sort. Turned out to be valve cover gasket and also (main leak) was from an o ring deep inside.. I think it was oil pressure sensor area.
@khaosaming avatar
Peugeot Citystar 200i, Vespa PX 200
@khaosaming avatar
Oil pressure sensor was the culprit here:
Lx 150 oil leak resolved
@kdude avatar
@kdude avatar
I had that exact leak but not as bad. Had too do with a gasket. I did my best too find it by cleaning up etc.. but couldn't locate it. Brought it too the shop and it took them two times too fix it. but finally it was sorted out. Around $300 if i remember correctly. Good luck
Vespa LX 150
Vespa LX 150
The oil leak is coming from the bolt with an allen head ( on top of the first photo). , the allon bolt in particular seen in the second photo.
Would this be where the oil sensor is located?
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
It more likely that that's just where the oil is settling rather than where the leak actually is. Have a look from above and see if you can see the leak higher up.
[ Time: 0.0087s ][ Queries: 4 (0.0027s) ][ live ][ 343 ][ ThingOne ]
