gts 250 p200e
gts 250 p200e
hi folks i have just connected the autolube back up on my p2 all is running fine apart from when i park scoot up at night i have a small patch of oil under scoot and this is coming from where the metal autolube pipe screws into the carb i have unscrewed and cleaned nut and re-tightened but still leaks but not as much so any help please also where can i get a new pipe ta
@aviator47 avatar
@aviator47 avatar
External inline image provided by member with no explanatory text to MV from the Sunny Aegean!
This thread has been moved to the Not So Modern Forum. That's where the folks who are shifty Vespa enthusiasts tend to hang out, giving you a better shot at a quick answer. NSM is home to all shifty Vespas, regardless of year and model.
For starters, you might give Beedspeed in Lincolnshire a call 01472 722 222
@trumpyscooter avatar
Black 2007 PX200, Dark green 1986 PX225 Pinasco, "1972"(yeah rite) Tangerine px200, several TRIUMPH TIGRESS SCOOTERS
hi dude, this happens and has been asked a million times. ive done a quick search for you and heres the results. Plenty of useful info to read through.
Oil leak coming from top of motor (I think from the Carb)
Oil/Gas leak into carb box
Help, I have the 2 stroke drip
2T oil pooling / leaking
Bought a '93 PX200e....it has an issue
Oil leak, puddle of oil appears every morning
Yeah so plenty of ideas here. Some people will tell you that it happens with these scoots, and thats fine. But ive got 2 vespas (and a current project) and neither of these leak oil on the ground, so it can be fixed with careful attention to fresh gaskets, secure hoses, sound float needles and turning off your fuel tap after parking up.
Best of luck and hi
[ Time: 0.0129s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
