@flat_tire avatar
Piaggio BV350
@flat_tire avatar
Piaggio BV350
Has anyone installed the plastic top case for a Piaggio BV350
I could some help?????
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Yes I have fitted one on mine .
Are you fitting the piaggio BV topbox or after market topbox ?
I fitted a smaller piaggio topbox from my gilera runner ST200 using the givi rack plate .
This is a thread here on fitting topbox on the BV
BV350 - Mounted a Givi Adapter and Givi MonoLock Case
@rkcoker avatar
Piaggio BV350
@rkcoker avatar
Piaggio BV350
Re: Installation BV350 top case
Yes, I installed a Piaggio brand top case. What's the problem?
@dailyrider28465 avatar
Mia Dolce II 2017 GTV 300, Ragazzo Vespa 946, Il Pazzo BV 350, & Mia Dolce GTV 250 -sold-
It's complicated
Be very precise about the length, orientation and location of each bolt, spacer, washer, and nut. They may LOOK like they fit, but if in the wrong place, won't work. Just go very slowly, one step at a time, paying close attention to the (barely adequate) diagram. It took me an hour and a half of assembling and disassembling the first time. By my third time, it took just 10 minutes.
@flat_tire avatar
Piaggio BV350
@flat_tire avatar
Piaggio BV350
BV 350 top box instalation
I purchased the Piaggio 36 litre luggage box. The direction are very vague.
It looks like I have to remove the plate on the luggage rack with a screw driver. Then install the heavy metal plate under the luggage rack.
Now the assembly packet gave me two large heavy barrel type "bolts"
I do not see these bolts listed in the directions?????
@rkcoker avatar
Piaggio BV350
@rkcoker avatar
Piaggio BV350
Those are replacement ends for the handlebars. They replace the plastic ones to reduce shaking and wobbling caused by the topcase moving the center of gravity.
@aplodontia avatar
Pending
@aplodontia avatar
Pending
Top Box Installation?
I saw a YouTube comparison of two sizes of top boxes they sell for the BV 350 and thought it had a pretty good overview of the installation. Of course I don't have one (yet?) so factor that in. Seems like a pretty fine ride for backroad touring and getaway weekends. Maybe ok for longer trips too?
Dale
@tclhb avatar
Piaggio BV 350
@tclhb avatar
Piaggio BV 350
Re: Top Box Installation?
Dale
I'm going to find out this month Dale. I'm planning on a trip up pacific coast highway from Southern California to San Fran Sisco later this month. 8)
[ Time: 0.0101s ][ Queries: 3 (0.0038s) ][ live ][ 343 ][ ThingOne ]
