cans! i almost slid out into traffic the other day because i happened to try & stop with my front tire (accidently) on a flattened aluminum can. it was like black ice! lucky for me the et4 is small enough that i just physically pulled it back (& was only going about 3 mph) to avoid getting taken out by a fast-moving cager coming around the bend. got my adrenalin pumping for sure!
Lucky escape, thankfully you were only going slow, we have loose stones at the end of the road, my hearts in my mouth every time I turn the corner
Russ |
Rocket Man
GTS 300 ABS 'Drake', GTS 250 (sold), LX 150 and Delta IV rocket. ( Retired. Not my problem anymore)
Posts: 1937 Location: Space Coast Florida |
Pulled into a store parking lot and drove right onto asphalt covered with wet oak tree leaves. Wow, what a great slide. Could've been a great utube vid!
lots of traction-reducing debris out there, i guess. just my luck to stop right on top of the ONLY can!
Resident Gentleman
Posts: 5046 Location: Brady, TX |
Scotty J. wrote: So.........the rear brake doesn't work? |
nope
Posts: 817 Location: I'm going there, but I like it here, wherever this is. |
bulivye wrote: ...btw, should i do something about the back brake? is what i posted above normal? |
Resident Gentleman
Someone more knowledgeable may correct me, but I think the ET2 & ET4, like my LX150 only have mechanical brakes on the rear; whereas they have hydraulic brakes on the front. Therefore, you will have a lot more braking power on the front wheel.
nope
danny*h wrote: Someone more knowledgeable may correct me, but I think the ET2 & ET4, like my LX150 only have mechanical brakes on the rear; whereas they have hydraulic brakes on the front. Therefore, you will have a lot more braking power on the front wheel. |
RIP
L
