I know it's a big question but....
I've got my p125x running pretty good now after rewiring the stator, new points, adjusting the timing, and using non-stock jets. But i know it should be even better; still got 'low power' (will it die?) when at low revs / moving off from idle. So, i'm thinking the jetting is not quite right yet, but not sure how to tweak it even further.
Carb, engine + exhaust is all stock for a '78 p125x, but the new 20/20 Spaco carb jets were not 'stock' (according to the Haynes).
The Spaco jets were;
starter:60/100, idle:45/140, main:96, air:140, atomizer:BE5
Haynes for a p125x 20/20 carb is;
starter:60/100, idle:48/100, main:98, air:160, atomizer:BE3
My jetting now is at;
starter:60/100, idle:38/120, main:96, air:160, atomizer:BE4
Anyone care to suggest where my jetting should go to from here??
cheers
