Short story - kick start not engaging. Disconnected clutch cable, and kickstart does engage. (Won't start like that though.)
What's been done recently-
Changed oil - case seems to have been empty of oil before then. Briefly filled with cheap 30 to get it running, and today changed it out with Motul 710.
Tightened clutch cable and gear selectors - there was a lot of play in the gear selector, and clutch did not seem to engage without a pull all the way to the grips.
Had it running, even whipped around the block up until 4th gear before I tightened the cables. That was a few days ago. Today, got it into 1st, then it seemed to slip out of gear and kickstart would no longer engage. Kickstart does engage without clutch cable.
Any thoughts on what is going on?
Is it possible the clutch cable was too tight?
Is clutch dead? Hasn't even been touched so far as I know.
Other possibilities?
