Hello,
please can someone confirm which way round the autolube gear is located on the crankshaft behind the clutch on my 1987 PX200e EFL? There is a 45 degree chamfer on the inside diameter on one side, but I don't remember if this faces the main bearing or the clutch. I read somewhere that the orientation of the chamfer differs from the non-autolube washer/spacer.
Thank you in advance.
