MP3 250 LML vespa
MP3 250 LML vespa
I think my regulator is not working. I'm not getting any charge at the battery.
The 30amp fuse is good.
As it happens I have a new regulator from a 300 Yourban but the wiring is different(as are the connectors but they can be changed)
They both have the 3 yellow wires from the alternator but the MP3 has 4 output wires basically 2 pairs.
The Yourban one has only 2 but they are much heavier.
Can anyone tell me if I could splice the 2 pairs together to make a single pair??
or what is the reason for having 4 output wires??
thanks
Yes, you can splice two into one - which is done internally in the old regulator. They just used two wires in parallel so they could use the thinner wire (cost?).
MP3 250 LML vespa
MP3 250 LML vespa
That's great thanks for that.
It seemed a waste to buy a new 250 one when I have a perfectly good regulator already
[ Time: 0.0087s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
