Before I scrap this original tear-drop switch for my 1959 VBA (with this one on SIP: http://www.sip-scootershop.com/en/products/switch+for+vespa+125+vnavnb1_89471500) I'd like to try to see if I can find a replacement part or two from one of you out there to keep this original piece in operation . . .
From what I can tell, it's the plastic headlight switch protroduing from the bottom of the switch that is broken. The plastic semi-circle should be actually a complete cirle and there may be other bits missing.
I found a photo of another VBA switch, but strangely, it looks a bit different than the insides of mine: VBA Electrickery: The Adventure Begins - Update 8/9/13
Mine doesn't have the same spring mechanism . . . Any ideas?
Thanks,
Allen
