1964 allstate 125
1964 allstate 125
Before I drive myself nuts trying to remove the rear axle castle nut on my 64 Allstate (VBN) scooter, is this reverse threaded?
I've used the search and cannot seem to find a definitive answer.
Specifically the rear castle nut holding the tire, not the clutch.
NO, lefty loosey, righty tighty. Spray some PB blaster on it. Try a little heat as well.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Counterclockwise, use air impact driver or breaker bar. Heavy friend on seat to keep tire from spinning helps.
1964 allstate 125
1964 allstate 125
Thank you.
Already soaking with PB, so I'll hit it with some heat and hope to pop it loose.
[ Time: 0.0099s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
