@the_falcon avatar
1966 SS180,1968 Sprint, 72' Rally ,74 V90, '64 GL 150 & too many projects!
@the_falcon avatar
Hi all,
I am trying to replace my rear hub seal on my Rally 180 and having a hell of a time of it ...
I got the tire and rear hub with no problem , but then there is a large castle nut and a spring clip . I cannot get the large castle nut to come off...
Does it go let to loosen>? it started fine then froze up after about a 1/4 turn and i cant get it to budge. If I am correct and was sent the correct seal then it must come off to replace the seal .... Anyways any tips or help appreciated as i am stuck ...
thanks in advance ~~
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
The oil seal sits inside the bearing retaining ring. Which is a reverse thread. I had a tool made to get mine off. The ring was banged up pretty good by the PO trying to get that ring off to replace the bearing.
BTW: I found a new ring at Scooters Originali. No one else had them at the time.
px200
px200
Hello
Am i missing something, you have the tyre and hub off and still have the castle nut on?
Grumpy
@the_falcon avatar
@the_falcon avatar
hi -
thanks for replies -
grumpy - there is a castle nut that holds the bearing in and is the seat for the seal ....so 2 castle nutz back there -
unfortunately the one for the bearing is reverse threaded - my damm foggy memory ... its what was giving me a headache - I ordered a new ring from Scooterwest as they were the only people could get a hold of that had 1.
After i did get the @_)%!#_%* thing off I found the seal i had ordered for it was the wrong one ... Which further frustrated me as I had specifically ordered over the phone to avoid confusion ...
Any way i do appreciate the response , now i'm waiting for parts to finish the job ...... Crying or Very sad emoticon
cheers all and happy scooting
px200
px200
Hello
When you get it out,you should be able fabricate a tool from the old nut,will it tap round with a drift.
Grumpy
@the_falcon avatar
@the_falcon avatar
hey Grumpy
I did get it out . i can start back in by hand - and can tap it round with a drift - but since i messed up the old one I would love to know what kind of tool can be made to do it without having the chance of messing up the new nut.
you have a pic of one ?
thanks~
@the_falcon avatar
@the_falcon avatar
hey Grumpy
thanks~
@greasy125 avatar
@greasy125 avatar
Grumpy wrote:
Hello
Grumpy
yes, early vintage motors have a castle retainer that is threaded into the case to secure the bearing (instead of the later circlip style) wherein the seal is located beneath.
-g
px200
px200
Grumpy wrote:
Hello
Grumpy
-g
Thank you.
Grumpy
[ Time: 0.0086s ][ Queries: 3 (0.0025s) ][ live ][ 339 ][ ThingOne ]
