Kdude,
I attended that class and made my own index. I was unaware of the wiki version. Regardless, here's my index. If I can figure out how to add to the wiki page, I'll do that tmw.
The class was excellent and the videos are priceless. I went because my dealer was floundering and I was afraid they'd fail. They did. I'll do my own first service in a couple months. I indexed the vids so I could find what I needed.
Best
Miguel
Link to my original post.
Part 1: Background and introduction of Rolf: He trained most of the Vespa mechanics in the US when Vespa re-entered the US market.
Part 2: Participant introductions including Glasseye and Jess (who dropped by for the day). Lots of wisdom in this section and getting to know the participants.
Part 3: Discussion of Vespa and the models by Rolf , more words of wisdom. Discussion of tires. Engine oil and levels. Oil filters. Transmission oil and a trick to changing the transmission oil.
Part 4: Vespa keys. Discussion on ECU. Programming keys, Discussion of Vespa Service and service intervals, Fuel filter discussion, Coolant discussion and draining the radiator, Auxiliary cooling fan. Thermostats and bleeder screw.
Part 5: More discussion on coolant, LED dash light diagnostics, operating Rolf's hydraulic lift. Oil service, begins at 22 minutes. Removing the transmission cover to access belt, variator, clutch. Lots of tricks by Glasseye here. Begine at 35 minutes. Also discussion of tools needed.
Part 6: Rolf and Glasseye explains how the continuously variable transmission system and variator works. Comparison of different variator holding tools. Discussion of various rollers. Discussion of the rear bearing in the transmission housing. Discussion of J Costa variators. Replacing the belt. Description of the belt direction. Discussion of clutch bearing.
Part 7: More on replacing the belt. Rolf advocates removing the foam filter in the front of the transmission cover. Torquing the variator nut and putting the transmission cover back on. Lots of warnings.
Part 8: Installing the transmission cover and torqueing the rear axle nut. Removing the exhaust, rear wheel, looking at the rear brakes. Meeting Jeff the regional Piaggio western sales manager who stopped by Rolf's. Rolf shows off his refurbished Vintage 160 (I think) Vespa - beautiful!!
Part 9: Rich explains the clutch operation. Removing rear shocks so the motor can be tilted and provide access to the valve adjustment. Adjusting the valves.
Part 10: Lots of miscellaneous topics - batteries, relays, stories from Rolf, etc.
