this may have already been done to death, but, am wondering if there's something that can do this out there on the interwebs. i know one can googlemap driving directions from point A to point B, but is there a better way of staying off the high speed, more crowded highways in order to take the 'scenic routes'?
![]() UTC
2013 Honda CBR500RA ABS, 2005 Vespa PX150 w/ GickSpeed 177
Posts: 550 Location: Canadian in Alabama |
![]() 2013 Honda CBR500RA ABS, 2005 Vespa PX150 w/ GickSpeed 177
What Rev said - and I'd start scrounging around to check out motorcycle route websites. (Motorcycleroads.com comes to mind, but there's not a ton of routes there around IL/IN area.) Some people post their rides + notes about it, and while you may not plan out an A to B route that's real direct by checking out the sites, you will find some interesting stuff =)
![]() UTC
2x 2018 Piaggio Liberty S 150
Posts: 64 Location: Lafayette, IN |
![]() UTC
Posts: 8758 Location: Annapolis, MD, USA |
![]() 2007 Vespa LX 190, 2011 LXV150ie
Google Maps' "avoid highways" option works MOST of the time.
I found two notable exceptions, one on a trip into western Pennsylvania where the recommended route turned into an on-ramp for an interstate, and the other near Wichita in Kansas where the recommended route crossed an interstate. The only way to get to the other side of the interstate was to get on via a ramp on the right side, quickly work your way across 4 lanes of high-speed traffic, and exit on the left! |
Re: Is there a "back road" route planner out there
bulivye wrote: this may have already been done to death, but, am wondering if there's something that can do this out there on the interwebs. i know one can googlemap driving directions from point A to point B, but is there a better way of staying off the high speed, more crowded highways in order to take the 'scenic routes'? The other thing to keep in mind is that some backroads may have pretty high speeds. I recently road up to Schaumburg from Oak Park on backroads. There are a few sections where the speed limit is 55mph which means people were going 70. A few other spots where you'd need to be cruising at 50-60 to keep up in traffic. |
thanks everyone! now, how did i not see the 'avoid tolls & highways' option? brain farts i guess. anyway, cheers & i'll give it a go!
![]() 2006 Vespa GT (Rocket): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125: 2018 Yamaha Xmax (Big Ugly), 2023 Vespa GTS300 (Ghost)
Posts: 5316 Location: Jacksonville, Florida |
Once you select the route from A to B using the "avoid highway" route, check alternative roads using street view. If you find a better one just pick on the route and drag it to the better road. It will go with you, but you may have to adjust other parts. I have used this method to find some very fine roads, even in my North Florida, South Georgia area.
![]() 2016 GTS 300 Super - red, of course.
Posts: 4755 Location: Hertford, North Carolina |
Take the results with a grain of common sense. I have seen an "avoid highway" route take a ridiculous loop this way and that just to avoid a few miles of Interstate.
I do my own planning with my copy of DeLorme's Atlas and Gazetteer for North Carolina. It contains "detailed topographical maps, back roads, recreation sites, GPS grids". Occasionally an interesting-looking side road turns out to be a muddy track, often with a gate! [url]www.delorme.com[/url] |
![]() UTC
2007 LX150 2015 GTS 2017 BV 350
Posts: 12469 Location: Fond du Lac, Wisconsin |
![]() 2007 LX150 2015 GTS 2017 BV 350
RevToTheRedline wrote: I just use google maps and select "avoid highways" works 99% if the time Seriously, it's great. |
There's a site called Motorcycle Roads that has a planner and several suggested routes for your state. Here's the URL:
http://www.motorcycleroads.us/ Hope that helps.
Positive
rkcoker wrote: There's a site called Motorcycle Roads that has a planner and several suggested routes for your state. Here's the URL: http://www.motorcycleroads.us/ Hope that helps. |
Piaggio BV250
Posts: 2429 Location: Historic Route 66 in Oklahoma |
Piaggio BV250
The Harley-Davidson factory website has a "Ride Planner" feature, that appears to be Google Maps with a few goodies loaded into the mix. It is quite easy to establish, change, print, and save routes with this.
