film worker wrote:
Yeah, I'm just collecting opinions on setting timing at 19 BTDC rather than stock setting of 22 BTDC due to the understanding that EI ignitions burn hotter and faster.
the timing of old was more advanced than these modern times due to better fuel back then.
Run as advanced as you can
higher octane allows the rider to advance their timing to squeeze out a bit more power but that can go bad due to greater heat in the top end.
19 BTDC is a compromise between ease of starting, WOT power and overall reliability.
if you buy a variable ignition then you can set the idle around 23 BTDC and it shall retard to safe cool timing in the upper rpms = 15 BTDC
