(Edited 5/19) This brake lock can be used as a standalone as a disc lock and then when used with cable you can use it like any other lock, just loop the cable thru spokes or frame then connect cable ends together with lock. You can also disengage the alarm feature by removing batteries and replacing if you want use alarm feature.
Brand New!
Complete set: Disc Lock with Alarm and matching cable
Xena Lock:
Xena XZZ6 Disc Lock with Alarm:
High nickel-content stainless-steel mono-block construction with a broad fit profile and 14mm double-locking, carbide-reinforced hardened-steel locking pin. Freeze-spray proof, pick-proof key and barrel.
Alarm: Shock and motion sensors trigger a piercing 120dB anti-theft alarm powered by a single CR2 long-life Lithium battery (battery included). Self-arming, with no on-off switch, re-sets to armed mode within 15 seconds.
Xena Cable:
Matching cable..this design locks cable ends within the XZZ6 housing and extends the reach of the XENA disc-lock alarm to tether to a fixed object such as a pole or ground anchor -- all with your XENA disc-lock in place on the brake disc.
$90.00 Plus shipping (USPS Priority or Flat Rate Box $12.35) = $102.35
PayPal will be used to complete transaction.
Thanks for looking![/b]
