@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Yesterday I removed the front glove compartment to install a new right leg trim. A frustrating task. But I did it with minimal amount of scratches to the trim. In the process I had to screw the cover on three times because the immobiizer/transponder aerial antenna kept coming off.
Now I turn the ignition key to the start position. The instrument panel lights up with the green headlight and oil red indicator lighting up as well.
I tried to start the scooter. Initially I could hear the starter and then just a swishing noise. Today I can only hear the starter trying to roll over.
but the engine does not fire up. After screwing the cover back on several times I noticed that the code light is not lighting up at all. Ah!
Even after having removed the key both in the off and lock position I found no joy. I thought maybe attempting to reprogram by using the master key might help but it didn't. The code light continues to stay off.
I am thinking that my antenna aerial is the culprit since I might have used some excessive force removing the cover. It came off several times as I maneuvered everything to tighten the screws back on.
The antenna looks a bit worn right at the connection to the ring. As you can see it is a one-pice (unlike the GTS's) and there is not a connnector to
remove at the ring end.
I removed the rubber boot at the other end adjacent to the ignition control unit to look at the connection and it looks okay (please see photos).
Today I have checked the main fuse under the 'no pet' carrier and the corresponding one in the glove box block as per manual electrical diagram
and they are both fine.
I have just performed an evaporectomy so I thought I might have compressed the HT coil bundle on the left upper middle underseat compartment.
The manual says that the ignition coil and the CD
The scooter was starting just fine before. What is going on?
PS. Meanwhile until I get some feed back from you my battery needs a bit recharging so I put it on the tender until I get a green light.
Leg Trim With Small Inperfection (My Fault!)
Connection to the Ignitionn Unit
Antenna
Antenna
Bundle
Disconnected with Sleeve Off
Bundle Disconnected with Sleeve Off
The antenna wires are very brittle, and break easily. Check for continuity through the antenna.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Will do that just after I finish my breakfast. Will have to put a new battery in my voltimeter for thecontinuity check. Projects! Projects!
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Update
It turned out to be some corrosion in the connectors. I had a friend help me with the continuity check. Just using a paper clip on the connectors to aid in the check seemed to solve the problem.
What is the antenna and what does it do?
It senses the RFID chip in the key, and is part of the immobiliser system.
@nickoneill avatar
2006 Granturismo
@nickoneill avatar
2006 Granturismo
Immobilizer/RFID antenna. It reads the RFID chip inside your key to make sure it's the correct one for starting the engine. This is why you can't just get any old key as a copy of your red/blue key.
[ Time: 0.0145s ][ Queries: 4 (0.0052s) ][ live ][ 334 ][ ThingOne ]
