Hello ALL! First let me introduce "us". This weekend I purchased a 2009 Vespa GTS250ie for my girlfriend Jenny to ride. I will also ride it from time to time but it's mainly so Jenny can ride along with me when I ride my Suzuki Vstrom DL650. Jenny is new to riding and is learning on the scooter.
We got the scooter used from a local dealer. There was one known issue. The odometer read 350 miles but the title says 4500 miles and says there is an odometer discrepancy. The dealer said that he honestly believes based on the condition of the scooter that it truely does have 350 miles as the odometer says but that it could have more based on the title. He said most likely when it changed hands in the past someone wrote the wrong number on the title and figured they would have surpassed the 4500 miles by the time they sold it and didnt but he obviously couldnt guarantee it had 350 miles. It had brand new looking Pirelli tires that looked like they had around 300 miles on them, so asuming those are the tires that come with the scooter, they help confirm that story.
So my first question is if messing with the odometer is easy on these Vespa GTS250's? Is this something that is common? Is there a specific part in the bike that sometimes needs replacement that would change the odomter back to zero?
The scooter drives great and I really love it. It turns out it has a custom baby blue paint job. That explains why I wasnt able to find a picture of it while searching around. I realized it was originally red after finding some hidden spots that werent fully painted. The paint job was done very professionally though.
The 2nd issue we had was that after riding it in the parking lot with my girlfriend learning how to control the throttle it started to STINK. It smelled like maybe mold or mildew.. THe dealer admitted that it was sitting in their moist basement all winter, I assume some mildrew grew somewhere and caused the stink. It seemed to go away after I drove it all day however. So my 2nd question would be if this is something to be concerned about at all, or just normal and nothing to worry about? The scooter had gotten a little warm (temp gauge was 1 bar over normal) due to my gf stopping and going in the parking lot and probably not enough air moving over the radiator. As a matter of fact, I think the smell started when the radiator fan kicked on for the first time.
The next issue we had is that I noticed on the ride home that the high beam dash light was off. I then confirmed the high beam light was off completely along with the low beam. I figured the bulb was blown. Fast forward to when we need gas (bad) and we were unable to open the saddle to get to the gas tank! I found the emergency mechanical release but it doesnt work! I hear it making a little bit of noise in the back (so the cable isnt broke I guess) but its not actually moving the actuator release at all.
So my 3rd question is if there is any suggestions on how to find the issue with the emergency seat release and fix it?
After the manual release wasnt working I started to get worried (we didnt get a manual with it). I started checking the fuses. Turns out the 15 amp fuse for the head light and the seat release was blown. I replaced it and we were able to get the seat to pop! Luckily were able to get the gas tank filledc.
My 4th question is if this is something to be concerned about? I know fuses usually blow for a reason. Could this be some kind of electrical issue to worry about? Is there anything to check? Is this normal at all? I will keep spare fuses on the scooter but if it keeps blowing then I would be concerned the scooter has a problem.
My next question was answered by someone who was helping me pick out a scooter on reddit. I said after we shut it down, 15 min later we heard a random buzzing coming from the rear of the scooter every few seconds. It went away after I started it, and we heard it again eventually later when it was off again but only a few times and less often. The guy on reddit said this is normal and is the carbon canister activating to remove fuel vapors. So I guess there is no issue here.
Next thing I noticed is that when I pull the rear brake when sitting at a stop, that the scooter shakes and vibrates a lot more than normal. It doesnt seem like a problem (brakes work great and engine doesnt stall) but it doesnt do it when I pull the front brake. I want to make sure this is normal. The mechanic at the used bike dealer said it was normal on scooters with larger engines, he said something about the automatic clutch causing it. Is this in fact normal?
Lastly, we only got a single key (red/brown color) thank god the manual says this is the master key. (LUCKY here). I am going to get a replacement key I found a couple places that sell them: http://www.motorcyclekeys.com/vespachipkey.html and http://www.allmotorcyclekeys.com/proddetail.php?prod=GT15RDT5 but the latter says you must get it cloned (cant be programmed) but the former says it can be cloned or programmed. ANyone have experience with either of these keys? I was going to get the one that can be programmed so I can do it myself on the scooter. I was also going to check the local vespa dealer to see what they charge. We did NOT get the code card that comes with the scooter though but based on my research on this forum, it doesnt seem like it will be an issue.
THANKS much everyone for reading and helping! It's exciting to join the ranks of Vespa owners!
12
