Can anyone confirm if I should experience a noticable increase in vibration through the frame/headset over a stock P2? I'm using a new 60mm Tameni crank and all new bearings. The vibration is most noticable going up through the rev range. At higher RPM, it seems to smooth out to an acceptable level.
I'm using the base gasket and VRH head supplied with the kit, admittedly bolt on at this stage. Is the compression typically high with the Pinasco setup, and could this be responsible for the vibration? Is the vibration just normal for this type of ride? My engine and suspension mounts are new and upgraded.
Cheers
