Vespa T5 classic
Vespa T5 classic
Hi guys, just collected a t5 classic at the weekend but no keys, been and bought me a new set of barrels and keys, but how do you get the old ones out without causing damage to the bodywork? Please help as desperate to get her running
Cheers
Clive
@mrj avatar
ET3
@mrj avatar
ET3
Congrats on the T5 classic!
The instructions are on a P-series but I'm sure most will translate over to the T5.
Jackson and Bitza are T5 owners and I'm sure they'll chime in to get you sorted.
Steering lock.
Ignition Switch
Good luck
@greasy125 avatar
@greasy125 avatar
if any of them are locked, you'll have to drill them out. it's a real party.
unlocked, then it's as simple as removing some bits and knocking the new stuff in.
best,
-greasy
Vespa T5 classic
Vespa T5 classic
Tried drilling the glove box lock and totally butchered it, not a problem tho have now ordered a new unit, but wary of doing this on the combined ignition / steering lock, any specific help guys?
@jimh avatar
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
@jimh avatar
Sorry I had not seen this earlier.
If the seat is unlocked remove it (lock) and mail it to me. The T5 classic has the Zadi lock, whereas all 3 locks are keyed the same. This will save you any headache.
The seat lock is the easiest to remove and fit keys to.
Proceed with caution if you are drilling the ignition/steering lock.
Cheers
@jackson85 avatar
@jackson85 avatar
Could you take the lock out of the seat and take it to a locksmith?
@jimh avatar
MV Saint
MV Saint
@jimh avatar
On a Zadi ignition.
There a several methods to remove a Zadi ignition for replacement, this is the method I choose.
Remove the horn cover on the front of your T5 Classic. There is a small indent on the Piaggio hexagon (on the right), use a small flat blade screwdriver to remove it. Now remove the philips screw and lift slightly, disconnect the horn wires.
Remove the electrical connector on the back of the ignition, then the 2.5mm allen screw. Pull the cam "T" on the steering lock tab towards you, just enough to avoid drilling into the back of it.
Now to the lock. Take a 1/8'' drill bit and drill the dust cover (gate) this will move aside as the drill enters the lock. Drill two holes 23.85mm top and bottom (see photos), you should now be able to clear out the wafers and pull out the plug only.* If you take your time you won't have any issue with the lock housing.
If you need to replace the actual housing, then you can use a punch and drink a few beers.
Cheers
* A cheap dental pick works great once the wafers are drilled/destroyed.
Vespa T5 classic
Vespa T5 classic
Thanks Jim, will give it a go tomorrow, next time I will do the easy thing and send them to you lol, your a star
Vespa PX200
Vespa PX200
Nice 'How To' apart from this part. That's not a Ø since you already said to use a 1/8'' drill bit. Are you suggesting people measure centre to centre with that level of accuracy? And then to drill with a handheld drill?
@jimh avatar
MV Saint
MV Saint
@jimh avatar
Not sure I follow mate. You drill 23.85mm depth...... at the two locations in the photos. If you drill further in, you run the risk of hitting the hardened cam. This would most likely snap the drill bit.
The above is how you drill a Zadi lock without making a mess.
No hand held drill either
Cheers
Vespa PX200
Vespa PX200
Aha! depth, now I get it.
⚠️ Last edited by TCC on UTC; edited 1 time
Vespa PX200
Vespa PX200
By hand held drill I meant, well, hand held not hand powered.
Vespa PX200
Vespa PX200
You beauty, it works, just done mine. Came out clean as a whistle.
@subetherbass avatar
I think on LML I removed horncast, and popped back (plastic that wires go into) off, an ripped out th guts
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
wrong
that usually buggers the insert in the forks n the barrel moves in and out .... you can do the same with a panel puller n a screw n bugger it up
[ Time: 0.0141s ][ Queries: 4 (0.0051s) ][ live ][ 313 ][ ThingOne ]
