I was wondering if anyone has tried fitness compression garments under their riding gear for long or endurance rides... If so, what were your experiences?
Thanks!
12
![]() UTC
Thunder Thief
Posts: 2360 Location: in the blue ridge mountains of Virginia... on the trail of the lonesome pine..." |
Thunder Thief
![]() 2010 GTS 300 Super & 2015 Kawasaki Concours 1400 ABS
Thanks! |
![]() GTS 300 Super - Beau, Honda CTX700 - Big Red
Posts: 983 Location: Everett, WA, USA |
I've never tried them. Might be nice in the winter when I'm looking for layers to bundle up in. We recently bought our 12 year old a "cooling" shirt for him to wear under his armored jacket. But it isn't really tight. Just form fitting.
I had to google what fitness compression clothing is. I'm not convinced it would help at all. On long rides, I'm not doing much. The fatigue I feel at the end is mental rather than physical. At least for me. ⚠️ Last edited by SuperK2 on UTC; edited 1 time
![]() UTC
Thunder Thief
Thunder Thief
SuperK2 wrote: I've never tried them. Might be nice in the winter when I'm looking for layers to bundle up in. We recently bought our 12 year old a "cooling" shirt for him to wear under his armored jacket. But it isn't really tight. Just form fitting. I'm curious what the intended benefit is? ![]() |
froggieposition wrote: SuperK2 wrote: I've never tried them. Might be nice in the winter when I'm looking for layers to bundle up in. We recently bought our 12 year old a "cooling" shirt for him to wear under his armored jacket. But it isn't really tight. Just form fitting. I'm curious what the intended benefit is? ![]() Also, I edited my previous post because I googled what this clothing is and what it is supposed to do. In the summertime, I wear looser clothing because I hate to sweat. |
![]() UTC
Thunder Thief
Thunder Thief
SuperK2 wrote: froggieposition wrote: SuperK2 wrote: I've never tried them. Might be nice in the winter when I'm looking for layers to bundle up in. We recently bought our 12 year old a "cooling" shirt for him to wear under his armored jacket. But it isn't really tight. Just form fitting. I'm curious what the intended benefit is? ![]() Also, I edited my previous post because I googled what this clothing is and what it is supposed to do. |
I think that depends on your riding position too. What is your favorite position? If you are one the cool guys/gals hiding behind the flyscreen with your elbows all the way down to the floor board I wouldn't recommend anything too tight and constricting.
![]() UTC
Thunder Thief
Thunder Thief
Max6200 wrote: I think that depends on your riding position too. What is your favorite position? If you are one the cool guys/gals hiding behind the flyscreen with your elbows all the way down to the floor board I wouldn't recommend anything too tight and constricting. ![]() |
![]() UTC
2007 Yamaha Vino 125
Posts: 2714 Location: Geneseo, IL (Quad City area) |
![]() 2007 Yamaha Vino 125
When riding in hot weather, I pretty much only wear moisture-wicking shirts. Some of them are compression, some are looser-fit. The compression ones also do a good job of cooling the body when they are gotten wet, say in the rest stop bathroom.
I have worn compression shorts while riding, and to me it does feel better than cotton underwear. I don't know if it's a design thing or that it's wicking as well... When I'm doing long rides, I also like to wear some of my running socks, again which are moisture-wicking. I've got some from Under Armor, New Balance and Fila, but I like the UA ones best. They do help keep my feet feeling drier, both when running and riding. So, yes, I feel it helps. But there's only so much they can do. A long day of riding is still going to be mentally tiring, even if you lessen some of the physical fatigue... Mark |
![]() UTC
Thunder Thief
Thunder Thief
CubsKing99 wrote: When riding in hot weather, I pretty much only wear moisture-wicking shirts. Some of them are compression, some are looser-fit. The compression ones also do a good job of cooling the body when they are gotten wet, say in the rest stop bathroom. I have worn compression shorts while riding, and to me it does feel better than cotton underwear. I don't know if it's a design thing or that it's wicking as well... When I'm doing long rides, I also like to wear some of my running socks, again which are moisture-wicking. I've got some from Under Armor, New Balance and Fila, but I like the UA ones best. They do help keep my feet feeling drier, both when running and riding. So, yes, I feel it helps. But there's only so much they can do. A long day of riding is still going to be mentally tiring, even if you lessen some of the physical fatigue... Mark In the hot summers here, sometimes I won't even ride because it feels so hot. Sometimes it feels like I am getting dressed to go snowboarding with my full gear but it is 95f degrees air temp. I am planning a few long rides in the near future and want to make it the most comfortable possible. To reduce any discomfort with clothing or gear will be ideal. Then I can just concentrate on what I need to, the road and ride. |
![]() UTC
Beyond what I've already said, I've used a few other products/techniques to keep me cool on long, hot rides:
* A helmet liner. You'd think adding something else on your head would make you hotter, but it doesn't. It keeps your head/hair from sticking to the inside of your helmet. It can also be wet down at stops to keep your head cooler. And, as any bald man will tell you, your head radiates a LOT of heat... * Soaking my mesh jacket before getting back on the bike to ride. It may only provide temporary relief, but it's sure better than nothing... * I bought an AlpineStars evaporative vest. It looks basically like a sleeveless compression muscleman shirt, but when soaked, it's supposed to retain water longer for more evaporative cooling. Combined with the wet mesh jacket, it helps a lot for quite a while. (Though how long that while is depends on airflow, temp and humidity, i.e. how quickly the water is evaporating) * Not clothing-related, but I also have a 3L Nalgene Osprey drink bag. (Basically, Nalgene's version of a Camelback bag). It has a wide enough slot in the plastic around the mouth that I can hang it from the bag hanger on the inside of the leg shield on my MP3. Whenever I need it, I can just grab the tube and take a sip, even with my helmet on. Because as everyone should know, by the time you feel thirsty, you're already starting to get dehydrated. Staying well hydrated will also make you take bathroom stops, which you'd probably want anyway so you can stretch and re-wet your gear... I haven't done an Iron Butt yet, but I have done 800+ miles across Kansas and towards home on a day where my scooter said it was 107 degrees, and these things helped. I was still wiped out at the end of the day, though... |
![]() UTC
Thunder Thief
Thunder Thief
CubsKing99 wrote: Beyond what I've already said, I've used a few other products/techniques to keep me cool on long, hot rides: * A helmet liner. You'd think adding something else on your head would make you hotter, but it doesn't. It keeps your head/hair from sticking to the inside of your helmet. It can also be wet down at stops to keep your head cooler. And, as any bald man will tell you, your head radiates a LOT of heat... * Soaking my mesh jacket before getting back on the bike to ride. It may only provide temporary relief, but it's sure better than nothing... * I bought an AlpineStars evaporative vest. It looks basically like a sleeveless compression muscleman shirt, but when soaked, it's supposed to retain water longer for more evaporative cooling. Combined with the wet mesh jacket, it helps a lot for quite a while. (Though how long that while is depends on airflow, temp and humidity, i.e. how quickly the water is evaporating) * Not clothing-related, but I also have a 3L Nalgene Osprey drink bag. (Basically, Nalgene's version of a Camelback bag). It has a wide enough slot in the plastic around the mouth that I can hang it from the bag hanger on the inside of the leg shield on my MP3. Whenever I need it, I can just grab the tube and take a sip, even with my helmet on. Because as everyone should know, by the time you feel thirsty, you're already starting to get dehydrated. Staying well hydrated will also make you take bathroom stops, which you'd probably want anyway so you can stretch and re-wet your gear... I haven't done an Iron Butt yet, but I have done 800+ miles across Kansas and towards home on a day where my scooter said it was 107 degrees, and these things helped. I was still wiped out at the end of the day, though... Thank you! |
eeeee bip
![]() BMW R1100RT The Problem Child Kymco Downtown 300 - I'm not the Uber BMW R1200 RT Big Red
Posts: 21482 Location: South East Great England of Britishland |
![]() UTC
Thunder Thief
Thunder Thief
Bill Dog wrote: Wuss. Bill x ![]() |
eeeee bip
Biffa
I think for Cannonball and Ironbutts 1 and 2 I wore tracksuit bottoms under leather riding trousers.
Lycra is OK when it's warm but in the desert especially in Arizona it got really cold so the trakkies worked really well. Also try and keep your chest warm with tank top under your jacket to keep your trunk toasty. Bill x |
![]() UTC
Thunder Thief
Thunder Thief
Bill Dog wrote: I think for Cannonball and Ironbutts 1 and 2 I wore tracksuit bottoms under leather riding trousers. Lycra is OK when it's warm but in the desert especially in Arizona it got really cold so the trakkies worked really well. Also try and keep your chest warm with tank top under your jacket to keep your trunk toasty. Bill x |
![]() Looking for the next one, probably electric
Posts: 3702 Location: Babcock Ranch, Florida |
For many years the secret weapon of the Iron Butt riders has been bicycle shorts. The compression works well, and the pads are in the right place to do some good. I never used them on a long ride, but they got great reviews from those who did use them. I use them on bicycles, and wouldn't ride without them.
They seem to do men a lot of good...ahem. Maybe more than for women. Keeps "things" packed up and away from movement and friction. You don't wear underwear under them. They are the underwear. |
Grumpy Biker
![]() 1980 Vespa P200e (sold), 2002 Vespa ET4 (sold), 1949 Harley-Davidson FL
Posts: 5615 Location: Sparks, Nevada, USA |
![]() UTC
Thunder Thief
Thunder Thief
Tor2ga wrote: For many years the secret weapon of the Iron Butt riders has been bicycle shorts. The compression works well, and the pads are in the right place to do some good. I never used them on a long ride, but they got great reviews from those who did use them. I use them on bicycles, and wouldn't ride without them. They seem to do men a lot of good...ahem. Maybe more than for women. Keeps "things" packed up and away from movement and friction. You don't wear underwear under them. They are the underwear. |
Re: contents shorter than the title
![]() 79 P200E (Ruby), 62 Allstate (B-62), 63 VBB (Storm)
Posts: 4886 Location: Florence, OR |
I frequently wear 2XU compression tights under my pants whether I'm going for a ride or not! I ride a bicycle a fair amount and have some basic tights I've worn for colder weather.
But the 2Xu compression tights are great for a day of riding. Can I tell if I feel better because of wearing them? Just barely. It's hard to do a day by day comparison because every day you feel a bit different, different conditions, different ride, weather, etc. Overall, I do think they help. Only have the one pair of tights, no tops or socks. Hope this helps... |
![]() UTC
Thunder Thief
Thunder Thief
Max6200 wrote: Bill Dog wrote: Wuss. Bill x ![]() ![]() |
![]() UTC
Thunder Thief
Thunder Thief
qascooter wrote: I frequently wear 2XU compression tights under my pants whether I'm going for a ride or not! I ride a bicycle a fair amount and have some basic tights I've worn for colder weather. But the 2Xu compression tights are great for a day of riding. Can I tell if I feel better because of wearing them? Just barely. It's hard to do a day by day comparison because every day you feel a bit different, different conditions, different ride, weather, etc. Overall, I do think they help. Only have the one pair of tights, no tops or socks. Hope this helps... Doing the mental planning.... |
Cool. Interestingly enough, I won't even go on a ride more than 4 hours without the tights on, under my jeans of course. Maybe I just feel like superman if I'm wearing them. Haha!
![]() UTC
Posts: 4213 Location: San Diego |
![]() 2017 BMW R1200GS and 2010 Vespa GTS 250 (shared)
While not "gym" gear; Cyclegear makes a compression like top and bottom for cold or hot weather to wear under M/C pants instead of a liner. I have the warm weather variation to wick away sweat. So far it works really well.
![]() UTC
Red Devil SH150i (11,000)
Posts: 3325 Location: Orange Park Florida |
![]() Red Devil SH150i (11,000)
Maybe some padded board shorts, I used them when wakeboarding. I haven't used them for riding, but they do a great job preventing a sphincter spanking
![]() UTC
Thunder Thief
Thunder Thief
Knight Train wrote: While not "gym" gear; Cyclegear makes a compression like top and bottom for cold or hot weather to wear under M/C pants instead of a liner. I have the warm weather variation to wick away sweat. So far it works really well. Thank you. I think temperature for the ideal ride will be 60-85f. Now looking at a window of weather and route |
YaYaDave wrote: Off Topic Don't forget the subtile fatiguing effect of constant noise. Ear plugs? |
Max6200 wrote: YaYaDave wrote: Off Topic Don't forget the subtile fatiguing effect of constant noise. Ear plugs? ![]() ![]() |
Grumpy Biker
![]() UTC
Thunder Thief
Thunder Thief
caschnd1 wrote: YaYaDave wrote: Off Topic Don't forget the subtile fatiguing effect of constant noise. Ear plugs? |
![]() UTC
Thunder Thief
Thunder Thief
Max6200 wrote: Ideal temperature if you are not accounting for the rain and wind. |
eeeee bip
visit
Max. I actually prefer the pain.
If I try and make it easier I feel like I'm compromising. Bill x |
![]() UTC
Thunder Thief
Thunder Thief
Bill Dog wrote: Max. I actually prefer the pain. If I try and make it easier I feel like I'm compromising. Bill x ![]() |
![]() S50, R1100s, way too many pushbikes
Posts: 11025 Location: Hermit Kingdom |
Re: visit
Grumpy Biker
caschnd1 wrote: Take a supply of this for the long rides... ![]() -Craig |
caschnd1 wrote: caschnd1 wrote: Take a supply of this for the long rides... ![]() -Craig Johnson's baby powder works too, but who wants to smell like that? |
![]() UTC
Thunder Thief
Thunder Thief
caschnd1 wrote: caschnd1 wrote: Take a supply of this for the long rides... ![]() -Craig I am picturing clouds of powder behind me and on my black gear pants. |
