Hello Vespa Gurus, I need a little help.
I am recommissioning a Rally 200 that hasnt been used since the 80's. Apart from the obvious carb and fuel tank cleaning and new seals, I thought the bike would be good to go with only 1,500km on the clock, no rust, its amazing... BUT it had no spark. I inspected the stator and it was bonkers, 500 ohm resistor (not 250 ohms), yellow and green were earthed somewhere, etc...
So I sent the whole femsatronic system and stator to Alan at Beedspeed. He told me it had multiple issues and had probably never worked properly which the mileage of the bike confirms. I restore cars, so keeping things original when you have a nice one is paramount. Despite this I was told the bike would be improved with Vespatronic Ignition System for the femsa crank, so I placed my order...
When it arrived I was not happy at the lack of instructions, just some sketchy wiring diagrams that may or may not be relevant to my bike.
Long story short, I have no idea if I have the correct flywheel for the kit. The flywheel goes on the crank, but not very far and catches the flywheel cover to the point where it cannot be replaced.
Alan at Beedspeed suggested:
cutting the flywheel cover (not an option on such a perfect machine)
spacing the flywheel cover (almost 10mm from the casing at the bottom)
cutting the fan blades (there wouldnt be much left)
spacing the fan (even though it would stick out more?)
None of these are acceptable options. After being slandered by the staff at Beedspeed, the frustration led me to do my own investigating...
The femsatronic crank has a taper and a straight, the later crank is a straight taper... when I removed the flywheel and inspected the inner taper , it is straight?????? Has someone put the wrong flywheel in the box?
I spoke to a few vespa shops who said they had fitted these kits with no problems, others said they had to make a few mods....
I did a test with masking tape on the crank to see where it was contacting the surface of the flywheel and it only makes contact on the last bit of the 16mm taper section.
I'm pretty sure I shouldnt be able to use a straight edge on the flywheel to show no changes in pitch to the taper....
I have emailed and phoned beedspeed, they told me to contact italy. Italy havent answered my emails (with pictures) and even SIP havent responded.....
I have been offered a refund by Beedspeed which I think is the easy way out, this bike needs and deserves a spark
12
