@beats_walkin avatar
1983 PX 200E Elestart, 1984 50S - plus 1959 Velosolex 1700, 1963 Jawa-CZ 'armadni, 1970 Yamaha YB50 cafe racer, 1972 Honda CB 350 K4, 1979 Honda C50
After a couple of decades, a friend of mine is finally going to restore his Sportique. He mentioned something about the shell needing a reinforcing tube for the front fork behind the leg shield (we're looking to do a 10" wheel conversion), and possibly adding some reinforcement under the footboards to add rigidity.
As the plan is to run either a freshened-up, or at most, a 166cc kitted Bajaj 150, are the aforementioned body mods worth doing or a waste of time? Apparently a lot of VBB/Sportiques were done like this in NZ, but I'm not sure if that was a result of a weakness in the original design or a way of keeping rusty ones roadworthy... This particular example has a mint, if slightly dented after 50 years, shell.
Any suggestions/comments would be appreciated, as I suspect I'll be doing a fair amount of the engineering side of the project. Thanks in advance.
@joshzingzing avatar
only need to strengthen the frame if your gonna take sheep on the back
@scootermarc69 avatar
'Eh! McCloud! Get offa my ewe!
I take it you know that from personal experience..?
My mate's one of those guys who can find problems where there are none, hence my question about reinforcing the bodywork.
@ginch avatar
@ginch avatar
Next question?
there's your answer
there's your answer
Sad but true on my second comment...
No comment on the first...
Ginch's solution looks like the best, but I don't think this guy's going to get that serious with the build.
@ginch avatar
@ginch avatar
I put those pictures up not as a suggestion but to demonstrate (to your friend) that even though Scooter & Service chucked a 24 horsepower - somewhere around 4 times the original power - motor into that VBB, they still haven't strengthened the frame at all.
And in my opinion nor should your friend.
I agree with your comments, but did promise to ask for his peace-of-mind.
FYI, I've often been asked to sort out a 'major problem' with one of his scoots which almost always requires a minor adjustment of some sort.
Cheers!
A quick update: Spoke to my buddy this afternoon and he's happy that the body shell doesn't need reinforcing. Thanks for the comments, both humorous or otherwise...
I'm hoping that I can start gathering all the parts we need from around his warehouse and get the main shell down to another friend of mine to have a legshield crack repaired. The guy's collected a whole lot of N-O-S bits, along with enough parts to do a 10" wheel conversion.
Once we get started on the project, I'll photograph the progress and post it on the projects thread.
@ssteam177 avatar
vba vespa 210, API monza230
@ssteam177 avatar
Check ebay aust there is a fork to suit your project
Thanks, there are also a number of them sitting in the back of my mate's warehouse. He used to be the Piaggio importer and inherited a whole lot of parts.
I plan to tidy up an area in the warehouse where I can start collecting all the bits he's got so that we can make a start on the project. Once I've done so I'll post some pics.
[ Time: 0.0178s ][ Queries: 4 (0.0078s) ][ live ][ 334 ][ ThingOne ]
