@victor1 avatar
2011 LX150ie two tone expresso
@victor1 avatar
Many of you here are real computer experts, so here's my question. I have a Dell 470 precision work station and and one of the capacitors is starting to pop. It still works, but will be a problem in the future. My computer guy says replace the mother board. I see repair kits with the capacitors for around $20 or less. I've done a lot of circuit work but just want to know how hard of a job it is to replace a cap. I know the traces are small, but would think with a very fine point soldering iron it should be possible. Comments? Thanks in advance.
@dmpawley avatar
2013 GTS 300 i.e.
@dmpawley avatar
2013 GTS 300 i.e.
I used to scrape and solder boards, but now they are so cheap that it's mostly not worth it.
It can be done, but you have to make sure you don't short another path. A nail file should be enough for a shiny connection. Use acid core solder.
Otherwise, check the local computer store for a board/chip combination that will use your memory and get a bump up.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Re: NSR Mother board repair
I would jump all over that repair. I had to replace the capacitors on the power board for my Samsung flat screen TV about 2 months ago. It's a super simple repair if you are good with a soldering iron. Granted a computer mother board is going to be a little more complicated than my Samsung power board. Worst case, you fail and you are out the $20 for the capacitors and your time. Best case you save yourself $140 by not replacing your mother board.
In the case of my Samsung TV power board, I saved $200 by doing some research on the internet and spending 1 hour repairing the failed board.
-Craig
@bob_cowley avatar
GTS250, P200E
@bob_cowley avatar
GTS250, P200E
The capacitors are likely available locally for a very cheap price. Ask someone nearby. (Note: The above does not apply to high voltage capacitors for old tube equipment,) Be sure to observe the polarity when replacing electrolytic capacitors.
Never use acid core solder on electronic equipment.
You will need a solder sucker, available from Radio Shack or whatever they are called these days, also available from your local supplier of electronic parts.
Cheers and good luck,
Bob
@dmpawley avatar
2013 GTS 300 i.e.
@dmpawley avatar
2013 GTS 300 i.e.
My bad. I got them mixed up.
@burgman400 avatar
2008 LX 150
@burgman400 avatar
2008 LX 150
I have 3 DELL desktops with swollen capacitors. They all still work fine. Replacement mobos are approx. $100. These PCs are nearly 9 years old and still ticking. They have had upgrades to memory, hard drives, video cards and the OS to keep them functional. Once they die I will replace the PC not the board. Your Precision is a more expensive beast. I would likely replace that board. You probably have many caps that are problematic not just one.
@g03 avatar
MP3 500 08
@g03 avatar
MP3 500 08
Worth the effort to try, my concern is if the solder flows through the whole hole. Good circuit boards have hollow shafts driven through circuit board for parts. PC boards are multi layers with combining circuit paths between layers. A few over sea manufacturers have stolen eletrolytic test formulas from usa companys and used them. Before testing proved they fail after a few years time. To my knowledge, a Dell motherboard is not a standard exchangeable one. Heard they rewire the power connectors to their standard? So no other brand can be just changed out. Best of luck.
@web-tech avatar
@web-tech avatar
Dell makes all most all their own components, they don't "modify/rewire" off the shelf parts.
We see a few systems come through with off the shelf components, but those are just stop gaps till they get their own system built and in production. The Dell C2100 line of servers is a perfect example of Dell using off the shelf components to fill a void in it's storage line up till they got a new system into production.
@voneschenbach avatar
A fracking cage sadly
I am all in favor of trying to repair the board - worst case it doesn't work and you are not out much.
Likewise. Just don't use lead-free solder. Rosin-fluxed is fine as long as you clean up afterwards with some solvent and a toothbrush.
@paulm avatar
GTV300 & GTS300 & 946 & GTV250 & GTS300ABS
@paulm avatar
Repair it. You will most likely find that there are 2 or 3 other caps nearby on the board of the same value. Sometimes they all bloat at the same time and need replacing. If not bloated, replace them anyway.
I usually use a higher voltage rating.
Because the mboard has many layers, heat gets sucked away easily, so use a larger tip and if possible a slightly hotter iron, otherwise u battle to get the cap out.
I have screens and mboards that run for years after having replaced the caps.
Watch the polarity.
Good luck
A higher temperature rating helps as well. Often you'll see 85C caps - replace with 105C instead.
@rkcoker avatar
Piaggio BV350
@rkcoker avatar
Piaggio BV350
Don't do it unless you have an up to date repair station. Motherboards are more complicated than other electronics because they are multi-layer and very crowded.
@paulm avatar
@paulm avatar
+1 for higher temp rating.
[ Time: 0.0231s ][ Queries: 3 (0.0080s) ][ live ][ 313 ][ ThingOne ]
