After a brief stop, I tried starting the engine again. It started, but as I tried to pull off, it misfired and cut out again. So I phoned for roadside assistance.
After the scooter and I had been dropped off at my home, I tried starting it again, and it started perfectly. So now I have the hassle of locating an intermittent fault. First thing I checked was the spark plug lead, but that felt fine. There was plenty of petrol in the tank, according to the gauge.
Does this sound like fuel pump? My GTS250 is a 2007 model. I have a spare pump in the shed, but I understand it is a real hassle to replace one. Can one test it easily by disconnecting the hoses on the injector and switching on the engine to see if petrol is pumped out? (after it has cut out again and won't start).
I have left the battery on trickle-charge overnight, as it got hammered a bit trying to start the engine.
Mike
Edit: I suppose I can just switch on the engine/ignition and listen for the pump!
⚠️ Last edited by Mike Holland on UTC; edited 2 times
