@trumpyscooter avatar
Black 2007 PX200, Dark green 1986 PX225 Pinasco, "1972"(yeah rite) Tangerine px200, several TRIUMPH TIGRESS SCOOTERS
Hi guys. Im doing over a px fork and want to replace the lower supsension arm bearing pin. SIP part 17745100
http://assets.sip-scootershop.com/en/main/base/Details.aspx?ProductNumber=17745100
Has anyone done this before and if so how did you go about it? is it pressed out and then back in?
bump
px200
px200
Hello
This is a pain and requires a special tool (expensive) you will need to replace the bearings as well, have heard you can press the pin out with a monster vice, you will need to release the nadella bearings which have a star washer thingy that hold them in place, in the middle is a dimple which smack with a punch to displace the fingers.
Grumpy
px200
px200
Photo of tool.
thanks grumpy, i knew someone sensible would show me how its done. right, well best l research how to do this then.
Ive bought the pin and full bearings etc but if its too hard ill just let it live as is.
px200
px200
Hello
If you have the bearing set it will become obvious how the star washer works and how you release it with a punch.
Grumpy
[ Time: 0.0256s ][ Queries: 4 (0.0046s) ][ Debug on ][ 313 ][ Thing One ]
