@budz avatar
GTS 300 Super ABS/ASR (sold), BV 350 ABS/ASR (crashed)
@budz avatar
Hello, your thoughts please, would you buy this GTS
http://www.cycletrader.com/listing/2009-Vespa-GTS-300-Super-112946556
@dutch avatar
LXV 150 GTV 250
@dutch avatar
LXV 150 GTV 250
Looks like a pretty good deal to me. Wonder if they've got the maintenance records ?
Low mileage.
Look around here and you'll find all the questions you should ask the seller.
@huntbchsocal avatar
Vespa GTV250:: Et4 150
I would jump on that in a second
@budz avatar
@budz avatar
It was owned by an older retired gentlemen who split/spent his time between Florida and Connecticut. The dealer has replaced master cylinder and oil. My worry is if there is rust at the bottom due to time in Florida (salty sea air) and how much it will cost to get it in nice shape. But looks like a fun project and a good way to learn, I haven't worked on a scooter before...
It needs a new rear tyre and the belt and rollers will need changing as well - so factor that in.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
Yeah looks like a good deal even if it has some rust. Though the salted road of CT would probably cause more problems than the salt air in Florida unless he live right on the beach and parked it outside.
I'd buy it but see how it runs. Jump on it.
@budz avatar
@budz avatar
Are these expensive? Would after market ones (Dr Pully, Mallosi etc.) make it faster? Also, the front end, brakes and shocks look a bit worn...
@budz avatar
@budz avatar
It's in CT and I am in Washington DC but have friend in CT (rides sport bike GXR 750) who will look at it firs before I expend the effort.
But, so far your collective input is positive (given the limited info. provided). I am tempted to do it...
I have a friend here whose selling his 300 for twice that and it's been backed into twice. If you DIY maybe $350 for all the parts and changing the rear tire and the belt change isn't to bad. Tutorials on both. Good luck. Make sure there's 2 keys. Blue on and a reddish brown one tho. The reddish brown is the master key to the CDI. Ooops i forget that you get free shipping on some stuff there so my estimate is probably high. Good luck
The tyre isn't expensive if you take the wheel off and in to a dealer to get it changed - perhaps $90. Belt and rollers are DIY, say $80. The belt probably isn't worn, but will need changing due to age. The rollers are cheap enough to change at the same time regardless. On a 300 I wouldn't bother with an aftermarket variator, the performance is good enough as it is, but Dr Pulley sliders will make it slightly smoother on take-off. The brake pads may need attention, but unlikely at ~6,000 miles. Shocks may look jaded, but as sealed units, if they work and haven't leaked oil, they'll be fine. All that is pretty standard.
Your main effort will be on prettying up the body work, if you want to.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
I would jump on that given it pass my visual
@madison_sully avatar
Seems mis-labeled (?)
In 2009, wasn't the GTS a 250?
Also, it looks like the top case is not aligned with the centerline of the scooter; I'd check for damage around the seat pan from the crashes it has had (or it's just mounted off center).
From the corrosion and discolored plastics it looks like it was stored outside. Check the tires for cracking.
I would probably shove a Q-tip into the airbox through the bubble holes. The bubbles themselves are clear, which after that many years and miles I am inclined to think they were replaced. It's the sort of thing that makes me worry.
Even with all that, if I was looking I'd probably go for it, assuming it runs well during a test ride.
@wleuthold avatar
2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125: 2018 Yamaha Xmax (Big Ugly), 2023 Vespa GTS300 (Ghost)
@wleuthold avatar
At that price I initially thought it was a scam. But after looking at the photos, it is in questionable condition. Rust and corrosion are things that I avoid. If that corrosion is in the electrical system you might be buying a lot of headaches.
@budz avatar
@budz avatar
I didn't think about that, you make a very good point. So would you buy or pass?
@harvey avatar
@harvey avatar
They recalled due to fuel pump issues that year- check the vin for that. To me replacing the master cylinder on that age/mileage Vespa is a warning sign. Check the wiring, and the rear shocks (for rust) too.
@gulfcoastprimavera avatar
1974 Primavera 125
1974 Primavera 125
It looks like a great deal.
But is that amount of rust on exposed metal parts normal? I live in FL - not on the gulf - a few miles away - but that seems excessive to me... But I could be wrong.
Did Connecticut get hit by Hurricane Sandy?
I'd open it up and look inside as much as you can....
@der_blechfahrer avatar
I would look inside the battery case for more corrosion. Easy enough to do, especially with the battery removed.
The clock battery needs to be replaced. Tedious job.
@cdrpierce avatar
GTV300ie
@cdrpierce avatar
GTV300ie
Hurricane Sandy is the most important concern that corrosion looks bad enough to have been submerged in salt water. Still not a terrible price if you can get a couple of years riding.
@budz avatar
@budz avatar
Re: Seems mis-labeled (?)
checked the VIN number with Scooter West and it is a GTS 300 build in 4.10.2009, description matched the bike, they think it's a 2010 model.
@wleuthold avatar
@wleuthold avatar
It is a hard call, but I, personally, would pass.
@budz avatar
@budz avatar
The price is $1,500 so I asked for more photos and think this the bike isn't the right one for a first time project, the rust is too much. I am going to pass on this bike.
It seems WLeuthold had it right...
⚠️ Last edited by Budz on UTC; edited 6 times
Ugh - far too much rust to consider it as a financially sensible project.
@wleuthold avatar
@wleuthold avatar
I have never seen one that I would want less than this one.
make him a much lower offer considering the rust and all. Would be a nice project for around 1200 would be my initial offer
Give them $1000. Lots of rust but if it runs the parts might be worth something. Might not look pretty but it'll get you riding on a Vespa. see how low they'll go
Talk about no worries
More I see it the more inclined I'd be to buy it. I'm not in the market, and even if I was it's way too far away. Something about that bike just says "ride it like you stole it".
@cdrpierce avatar
GTV300ie
@cdrpierce avatar
GTV300ie
From the pics I'd pay a grand out the door if it runs and rides. The parts would be worth that but not a penny more.
@mgg avatar
2007 BV500
@mgg avatar
2007 BV500
I noticed the luggage rack looks a little off as well. I had an accident on my GT 200 where the frame was bent. The insurance company totaled it because it is very expensive to fix a bent frame. I would be very cautious.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
Wow - too much rust - pass
[ Time: 0.0340s ][ Queries: 4 (0.0088s) ][ Debug on ][ 313 ][ Thing One ]
