@jackthelad avatar
VNB 2T 125cc
@jackthelad avatar
VNB 2T 125cc
Hi Guys,
I'm considering converyting my wheels form the original 8" ones to a more practical 10" set.
Has anyone had experience of doing this?
Can anyone highlight the pros/cons of doing this, and any tips/advice before I embark upon doing it.
Thanks in advance.
@glscoot avatar
Vespa GS150, Messerschmitt GS150
@glscoot avatar
Can you be more specific, are you fitting a PX engine.
@jackthelad avatar
VNB 2T 125cc
@jackthelad avatar
VNB 2T 125cc
No new engine.
It's a 125cc, 3 gear VNB model.
Are the wheel conversions only meant to accompany an increase in engine power?
@glscoot avatar
@glscoot avatar
No.
if you want to convert to 10" and keep everything as it is at the moment, then SIP sell wheel rims that fit straight on to your current hubs, but in my opinion they are very ugly. Picture of your scooter would help.
@jackthelad avatar
VNB 2T 125cc
@jackthelad avatar
VNB 2T 125cc
Thanks for the advice.
Here's a pic of the scoot...
[/img]
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
We'd keep it 8". Unless you're swapping engines or otherwise planning to go faster than the brakes can safely stop the scoot, there aren't that many advantages to converting to 10".
@vader19 avatar
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
@vader19 avatar
Don't do it Jack... Just don't do it!
Leave the 8's = cool
Ohh the HUMANITY!!!
@glscoot avatar
@glscoot avatar
The roads are not the best over here in the UK, 8" wheels are not that safe over here. Potholes can swallow an 8" scooter every 10 yards.
Ive probably damaged around 3 shocks and split a few rims.
It is nice to see a 8" scooter now and again.
@rob_hodge avatar
@rob_hodge avatar
Re: 8" to 10" wheel conversion - 1961 Vespa VNB
JackTheLad wrote:
Hi Guys,
Thanks in advance.
honestly, it really doesn't make as much of a difference as you think.
in addition, to do it right it's a huge hassle.
first, there is the front.
the wrong way is to drop on VS4 10" rims or swap hub and brake components from a sprint. do this, and you will have issues with the wheel hitting the fender on hard braking, witch can be unsettling at the least, and dangerous at the worst.
you can try to fit a sprint fork, however the fork is about half an inch too long between the upper and lower races. to address this you'll need a die that costs about $80-120, or you'll need to cut the fork, shorten it, and reweld it. then you need to get the fender to fit.
you can drop a PK or smallframe fork in, while these are the right length between the races, the distance from the lower race to the center of the axle is longer. long enough to chopper out the front end enough to affect handling. and then there is the fender fit issues.
the easiest way to do this is to get a GS150 or GL150 fork. these drop right in and have correct dimensions. they are also fairly rare and hard as hell to get your hands on ; the last one i saw for sale on the open market went for like $200-300 and wasn't complete.
then you have the rear.
if you just put a larger wheel on, your gearing will suffer and you'll find that top gear is useless and the gaps between gears on that 3-speed become unmanageable. you'll end up raising the gearing about 20%. you can get about 10% back by a clutch swap to a 20 tooth clutch, but it'd still be an issue, especially on a 3-speed. many of the internal components you'd normally swap to lower the gearing on later engines are not compatible. you'd also need to adjust the shock spacer height to level the bike to make up for the increased distance between the front axle and the lower bearing race on the new fork setup.
And once you are all done, you'll find you've probably affected the handling worse than any perceived improvement that 10"s have over 8"s.
Alot of the perceived difference people have between 8's to 10's are actually frame geometry differences between the 60's bikes (the most commonly seen 8" models) and the 70's and 80's bikes (the most common 10" models). just throwing larger wheels on your scooter will not make it handle like a sprint or a P; there are many other variables in the suspension equation you don't even realize that Piaggio also changed between these bikes.
my advice? take the money you have allocated for this project and buy new shocks for both ends of the bike, a new stoffi's spring for the front, and a new set of good tires.
that would probably give you more improvement than you'd realize, especially if the suspension components you have are 50 years old.
⚠️ Last edited by rob hodge on UTC; edited 2 times
62vnb , 71 sprint ,1974 vespa90
8 inch To 10 look literally restarted , they sculpted the chassis back in the day with the rims that are on it as part of the whole design . Sell it and get a sprint or a P series . An old 125 is not made for daily driving in today's modern traffic anyway .
@haole avatar
2007 Vespa 250 gts / 1964 Vespa VNB / 1961 Lambretta Li150
@haole avatar
As a longtime MV member and the proud owner of a 61 VBA for a year.
I have found a ton of help on this site, the search box is an incredible tool!
When I use google, more often than not MV results top the search!
BTW, I contemplated swapping to 10", did a lot reading and to ME, the quirks of having a old bike is just that.
Shifting, useless mirrors, hand signals, knees rubbing on the legshield (I'm 6' riding a solo seat), and the brakes... To name a few.
It's a riding experience!
It's your bike, do what YOU want!
@vader19 avatar
Mr. Clean
Mr. Clean
@vader19 avatar
I just think that bike looks great on 8's.. it's a cool bike.
IF you have to go to 10's.. maybe just use the conversion rims (I think they look quite cool) .. then you can always go back to 8's very easily.. just swap the wheels.
@oopsclunkthud avatar
1:3
The problem with the conversion rims is that it makes the brakes even weaker. Now that may be seen as a plus as it lessens the risk of the wheel rubbing on the fender, but both are avoided by leaving it as 8in.
As for bad roads, San Francisco has some huge potholes and the difference between 8, 10, 12, 13, 14in wheels is just not that great in practice. The main difference between a motorcycle and a scooter being able to take these roads in stride is the amount of suspension travel being about 6in vs 2in respectively.
@jackthelad avatar
VNB 2T 125cc
@jackthelad avatar
VNB 2T 125cc
Thank you all very much for your quality responses.
Much food for thought...
It's something I'll probably re-address when the weather perks up in Spring.
In the mean time, thanks again!
@seamus26 avatar
@seamus26 avatar
Oh, and don't forget to swap those feet out for some yellow ones. It's a must.
@the_falcon avatar
1966 SS180,1968 Sprint, 72' Rally ,74 V90, '64 GL 150 & too many projects!
@the_falcon avatar
cool scoot~
I have to agree with the overwhelming majority here - 8's are cool and its a great looking scoot -
8 in wheels are actually quite fun to ride as they are so maneuverable . I used to have an Allstate that was a blast to ride. It seems like the work required to do the conversion right is not worth the outcome.
Anyway good luck with whatever you decide~
Cheers
@dcunited4life avatar
No moar Vespas...sold them all
I agree with Falcon above regarding riding an 8" wheel scooter.....just so much fun! I'm kinda actually going through the same thing with another project I have....found a VBA in a barn but didn't want the 3 speeds so I am currently amassing the componenets I need to stick a SPrint V. motor with VBB gears and a Polini top end in my VBA but keeping 8"s on her. All parts I kinda had laying around but I wanted to stick with 8's. Anyhow, get a P I'd say for the more reasonable commute and keep this one fresh.
[ Time: 0.0204s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
