Few tips from my side
1) mixer info
As mixer = phbh28
Av mixer = phbh30
The as doesnt work in the phbh30
In low rev its always way too rich, no matter which size
Sadly dellorto delivers it.sometime with the wrong mixer
And there are a lot of wrong infos online too
I also included this info in the gsf wiki phbh article
2) needle ventile
Always replace the 200 needle ventile, kts too small, the chamber is sucked empty. Even the si24 has 240 =2,4mm above the needle
I always replace it with a 300
3)
Si26 or phbh30? What to use?
Power is the same (can provide u diagrams if u like)
For rotary valve up to 20/22hp at the wheel stick to si carb
Above that and with a big new expansion chamber exhaust
(nope. Not the old. Ones: jl scorpion sip pm. Etc)
use a phbh, as it is a full carb it can be set better
and not a cropped carb like the si with small floating chamber and missing needle&ventile, where u have to make compromises with settings
A big box like the bbs is a expansion chamber exhaust
It hits ecactly the same curve as the sip v2
U can still. Use si carb with big boxes
4) rv vs rv
As i read malossi reed intake
In this case u can better stick to rotary valve
Whats the difference reed valve vs rotary valve on-road?
Surprisingly rotary with box is at same speed or faster than reed valve
Si25 rotary valve vs phbh30 with mrp rd350 reed valve
https://youtu.be/Wu2nxJsvDhk
(and its so much fun hunting and overtaking other acooter with big carbs and pipes with a simpe si box setup)
dont underestimate rotray valve and the good old si24
(si28? Way too expensive for a cropped carb u get 2 phbh30 for it)
