Fri, 04 Nov 2005 22:28:17 +0000
2015 Vespa Primavera 150
Fri, 04 Nov 2005 22:28:17 +0000 quote
In the last little while, the keys for my ET2 have been really hard to get in and even harder to get out of both the igniton and seat locks.
I thought my one set had just worn down a lot, so I switched to my backup set, but the same problem persists.
Have I ruined the inside of both locks somehow?
Is it the colder weather now? I don't recall this happening last year in the winter...
Can anyone else relate?
Fri, 04 Nov 2005 23:30:58 +0000
Consume Less & Share More
Fri, 04 Nov 2005 23:30:58 +0000 quote
If it was just your ignition lock, or just your seat lock, I'd say you probably have a bent pin in the lock mechanism. Try treating the locks with a dry lock product containing graphite (or similar lock lubricant). If that doesn't work, maybe its time to visit your local locksmith.
Sun, 06 Nov 2005 17:26:15 +0000
Reprehensible Misinformant
Sun, 06 Nov 2005 17:26:15 +0000 quote
sticky keys remedy
I use a pinpoint oiler and add 1-3 drops "where it counts" once a year....smooth as silk. 1-3 drops....
  DoubleGood Design
[ Time: 0.0244s ][ Queries: 3 (0.0051s) ][ Debug on ][ 299 ][ Thing Two ]
