Sun, 14 Dec 2014 19:57:24 +0000
Piaggio BV200
Piaggio BV200
Sun, 14 Dec 2014 19:57:24 +0000 quote
Any suggestions would be greatly appreciated on this subject. Couldn't find anything in search results. All other lights around the cluster work fine. I need to buy a shop manual for it but just got the scooter. Just can't stand that not working. Thanks in advance for any advice.
Eric
Mon, 15 Dec 2014 00:16:53 +0000
Grumpy Biker
Grumpy Biker
Mon, 15 Dec 2014 00:16:53 +0000 quote
I'd be surprised if it did work. PTW fuel gauges are notoriously inaccurate and prone to breaking. The shop manual is your best source to get a good method for pinning down the problem. It will tell you the expected voltages Crome the sensor in the tank at various fuel levels and help you determine if the problem is the tank sensor or the gauge.
-Craig
Mon, 15 Dec 2014 19:08:24 +0000
GT 2.4
GT 2.4
Mon, 15 Dec 2014 19:08:24 +0000 quote
If the bikes been sitting a while, the float might be stuck. You can put in about half a tank, and pick up the back of the bike about a foot and drop it a couple of times. This fixes the problem about half the time by freeing the float. If that doesn't work, find where the sending unit out of the tank plugs into the harness, disconnect it, and jump the connection to the harness. If the needle on the gauge moves, it's in the sending unit, if not, it's either in the gauge or the harness.
Tue, 16 Dec 2014 00:57:02 +0000
MP3 400 / BV250
MP3 400 / BV250
Tue, 16 Dec 2014 00:57:02 +0000 quote
Sending unit is just below the fuel filler cap. You need to remove the entire trim panel that has the fuel door on it. Also you need to be careful with the gasket on the sender. Mine leaked and there was no replacement available for it. We had to flood the top with gas tank repair epoxy. If the WIKI does not have the BV200 service manual Vespa Motorsport does sell it.
http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/Piaggio-Workshop-manual-BV/215
Fri, 19 Dec 2014 08:42:53 +0000
Piaggio BV200
Piaggio BV200
Fri, 19 Dec 2014 08:42:53 +0000 quote
Thanks for the replies. I'll post again when I get it figured out.
  DoubleGood Design
[ Time: 0.0258s ][ Queries: 3 (0.0066s) ][ Debug on ][ 297 ][ Thing Two ]
