I recently cleaned the carb on a 2006 LX150 to get it running after being stored for almost two years. Replaced with fresh fuel and started with no issue. Ran fine the first trip up the street when I tested it out. Next time my wife hopped on to ride, the engine stumbled when opening the throttle but then would catch up and run fine up to full speed. Tried letting it warm up, but same response.
This sound like an accelerator pump issue. I took the carb apart again and pressed the pump by hand. I got a small spit of fuel but not what I would call a spray or continuous stream. Is that right?
How do I confirm it is the accelerator pump? If it is the pump, can this be repaired/cleaned or need a new carb?
Thx for any help!!
