Any idea what this could be?
Was driving on the highway and suddenly a loud bang, the engine completely died on my 2005 et4. I went to pull over and there was an excessive amount of white smoke pouring out of the exhaust. Now when I try to start it all that I hear is the little fan next to the exhaust kick on, the engine seems completely dead. I checked the oil and it's half full.
Any idea what this could be? ![]() |
Grumpy Biker
![]() 1980 Vespa P200e (sold), 2002 Vespa ET4 (sold), 1949 Harley-Davidson FL
Posts: 5627 Location: Sparks, Nevada, USA |
Doesn't sound good. The white smoke being particularly bothersome. Do you have compression? It sounds like you don't. Try kicking it with the kickstand pedal. If you don't get much resistance, that's a sign of no compression.
-Craig |
I am sorry.
A compression test might be telling of the mechanical state of the engine, perhaps even the spark-plug too. Any oil leaks? Or do you think the oil was burned? |
Posts: 2143 Location: London |
It sounds suspiciously like the magic smoke has escaped from your engine. Without this our Vespa's cannot run. You made need to contact a mechanic and get them to inject the smoke back in.
No expert but sounds suspiciously like another thread... Turned out they blew a hole through the piston! Like others have said, it sounds nasty. Best leave it and get a mechanic to look, if something g has come away you don't want to do more damage. Well at 8000rpm the damage may well be truely done....
I hope it turns out to be good news! Hey, might be a perfect time for the 190 kit Hope all goes well! |
ET4 125 Piston/valve shot?
They too were driving down the highway and got a bang and loads of white smoke. Holing it's not this! Not saying it is this though, could be a number of things. |
Grumpy Biker
theknights20 wrote: No expert but sounds suspiciously like another thread... Turned out they blew a hole through the piston! ... ![]() -Craig |
caschnd1 wrote: Doesn't sound good. The white smoke being particularly bothersome. Do you have compression? It sounds like you don't. Try kicking it with the kickstand pedal. If you don't get much resistance, that's a sign of no compression. -Craig |
Grumpy Biker
wardr wrote: caschnd1 wrote: Doesn't sound good. The white smoke being particularly bothersome. Do you have compression? It sounds like you don't. Try kicking it with the kickstand pedal. If you don't get much resistance, that's a sign of no compression. -Craig -Craig |
BrendaEM wrote: I am sorry. A compression test might be telling of the mechanical state of the engine, perhaps even the spark-plug too. Any oil leaks? Or do you think the oil was burned? |
Hope it's just a coincidence! Would be odd.for two.et4's to do the same thing pretty.much at the same time..what's the milage on the scoot?
-Craig[/quote]
By compression you mean does the engine attempt to go on? Nope. The only sound is the little fan next to the motor that goes on, maybe that is the starter? The engine seems completely dead. I haven't tried the kickstand starter though, I will do that later.[/quote] Sorry. Autocorrect changed "kick start" to "kickstand". See if there is resistance when you push the kick start pedal. -Craig[/quote] Okay I tried the kick starter and it seems like it is trying to start a tiny little bit- in the slightest. What's weird is that the oil light goes on and off as I perform an attempt to kickstart it. Then when I try to start it with the regular starter button after performing an attempt to kickstart it- it again in the slightest little bit seems like it is almost trying to turn on - but doesn't come close. Then when I push the starter button again, it's back to entirely dead. Does this make any sense? |
theknights20 wrote: Hope it's just a coincidence! Would be odd.for two.et4's to do the same thing pretty.much at the same time..what's the milage on the scoot? |
Grumpy Biker
wardr wrote: Quote: Quote: By compression you mean does the engine attempt to go on? Nope. The only sound is the little fan next to the motor that goes on, maybe that is the starter? The engine seems completely dead. I haven't tried the kickstand starter though, I will do that later. -Craig Then when I try to start it with the regular starter button after performing an attempt to kickstart it- it again in the slightest little bit seems like it is almost trying to turn on - but doesn't come close. Then when I push the starter button again, it's back to entirely dead. Does this make any sense? -Craig |
Quote: Doesn't really make sense. This sounds like the diagnosis is a bit above your ability. I don't mean that in a snarky way. But from what you've described the problem sounds serious. Probably need a mechanic to look at it. -Craig I think my biggest mistake was that I was using this as my main form of transportation. This is NOT a vehicle to use as your main source of transportation. |
Nooo! There's always a way!
Second on the engine idea, you can find them cheap enough if you look hard enough |
theknights20 wrote: Nooo! There's always a way! Second on the engine idea, you can find them cheap enough if you look hard enough |
Well I understand when money's a struggle it's horrible when something goes wrong.
I hope by some miracle something comes through for you and your vespa lives on. And don't worry about not being good at mechanics, I've only just started to volunteer and honestly a diagnosis like this is far beyond me too. |
