@maniac avatar
2013 GTV 300 IE
@maniac avatar
2013 GTV 300 IE
Has anyone used a carry-on trailer from Lowes?
My Passat has a max towing load of 1000 lbs, and I figure
I could get away with one of the smaller trailers and my GTV300ie on weekend trips....
@dooglas avatar
@dooglas avatar
Sure , that will work. I put a small hitch (Class 3) on my Jetta and used it to pull a light utility trailer. I've hauled 1 or 2 scooters at various times with that set up.
⚠️ Last edited by Dooglas on UTC; edited 1 time
@rajron avatar
GTS 300
@rajron avatar
GTS 300
I have that, using Condor chocks:
External inline image provided by member with no explanatory textSide-send by rajron, on Flickr
@xmxer351 avatar
GTS 300 Super Sport
@xmxer351 avatar
GTS 300 Super Sport
i was planning on buying a trailer but then i realized i was only going to use it a few times a year and it might be better to go the uhaul route. they rent good, big, trailers for about $14 a day. then i dont have to keep up with license plates, tires and place to keep it.
@maniac avatar
2013 GTV 300 IE
@maniac avatar
2013 GTV 300 IE
Thanks guys!
Yeah I was thinking of going the UHAUL route, but they seemed more industrial and heavier. I have to watch my overall tow weight. VW USA is very cautious about their towing ability. I think its a litigation thing. Back in Europe Passat's & Jetta's pull caravans all the time....
Maniac
@xmxer351 avatar
GTS 300 Super Sport
@xmxer351 avatar
GTS 300 Super Sport
i put a class 3 hitch on my wifes 2014 subaru forester xt. i havent used it to pull yet but the uhaul web site says i can do their trailer and 1700 lbs of cargo with that car and hitch.
@dooglas avatar
@dooglas avatar
Yes, I use the Condor SCC-4000 chocks as well. They work great.
@maniac avatar
2013 GTV 300 IE
@maniac avatar
2013 GTV 300 IE
Rajron:
Can you tell me your trailers length?
Wondering if I can get away with 6 ft length for the GTV300 or go with an 8 ft?
Maniac
@gitder avatar
GTS 250...Fiddle III 200
@gitder avatar
I have a 5x6 trailer. 6ft length is fine.
@ravenlore avatar
@ravenlore avatar
And I notice you're hauling it with a CRV.
I've been thinking that the next time I get a new car, it might have to be bigger than my usual subcompact...because i might want to trailer somewhere. But i WANT a SMALL vehicle. I actually spent time last night trying to determine the smallest and least expensive vehicle capable of towing either a Vespa or a Scamp or something.
(apologies for the threadjack)
@bendcyclist avatar
2006 GTS 250ie in Silver
@bendcyclist avatar
Try to keep in mind that the tailgate section of that trailer is one HUGE parachute that will kill your gas mileage. Its much better to get something that has storable ramps.
Vespa GTS Super ABS
Vespa GTS Super ABS
Yea, with all the open spacing in that tailgate, I bet it would really work well as a parachute Razz emoticon Razz emoticon
Maybe you could jump first?
Vespa GTS 250ie
Vespa GTS 250ie
Harbor Freight trailers are remarkably tough and useful for the price.
@rajron avatar
GTS 300
@rajron avatar
GTS 300
Maniac wrote:
Rajron:
Maniac
I believe I have the 6' trailer, I'm at work and can't measure it right now, won't be home and awake for another 20 hours or so.
Another option would be the Harbor Freight 4' trailer, was able to pull a Buddy, and a Vespa 250. That trailer was so light and small it never felt as if I was pulling a trailer at all - difficult to reverse with because it is so small, quick turns and hard to see.
The trailers are initially inexpensive, but, after modifying it for towing scooters securely it adds up. Initial cost of the trailer was around $250, by the time it was ready for use it totaled around $600, still inexpensive and reliable, and easy to store it can be stored vertically - unlike the Lowe's.
By the way I went to the larger trailer because we ended up with two larger Vespa's and when I got the Harbor freight we had two smaller scooters - it could tow one Vespa and one small scooter, just couldn't tow two large scooters safely.
See attached:
I checked my trailer it is the 8', the 6' wouldn't work for my scooters with trunks and the trailer with attached ramp.
@vespasfw3 avatar
2006 Vespa GTS250ie, 2004 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
@vespasfw3 avatar
rajron wrote:
Maniac wrote:
Rajron:
Maniac
See attached:
I'm curious if you have to use an external ramp or how exactly you get the scooter on to the trailer. Also, did you cover the bed of the trailer with plywood?
@camper avatar
lx150
@camper avatar
lx150
I have used that trailer. Good, light and strong for what it is. Add a wheel chock for the front wheel and with the proper tie downs your set.
@dooglas avatar
@dooglas avatar
This has been my experience as well.
@rajron avatar
GTS 300
@rajron avatar
GTS 300
The trailer has three rails that aren't obvious in the picture, two on the outside which are permanent where the scooters reside and a middle one that is removable used as a ramp - the trailer floor is 3/4 plywood
[ Time: 0.0175s ][ Queries: 4 (0.0057s) ][ live ][ 313 ][ ThingOne ]
