@elvispa avatar
GTS 300
@elvispa avatar
GTS 300
Comments and Opinions invited...
This is not a new thing on the Forum, but in the event that some folks start to see it, I wanted to mention it.
Not long after I got my GTS (2009) I began to see some darkening of the headlight reflector. Lens is unaffected.
It got increasingly darker, and less functional as a reflector.
In response I put in higher output bulbs for more illumination (compounding the problem with a hotter bulb?)
Heat is the obvious culprit. I don't know if it is convected or conducted or both (it does affect the top of the reflector only, the headlight pic is upside down).
The socket does seem to have discolored with heat, but is not melted.
Finally, I switched out the whole unit. I am mostly clueless on this one. The dealer claims that nothing is wrong with the wire/socket. There were some reported issues with the connectors on this forum but I never saw where there were details on the problem or solutions.
These headlight units are not "sealed" units, with a unique atmosphere, but they do not pass air easily from outside to inside, etc. I am wondering if some small holes in the reflector above and below the bulb might give some thermal dissipation.
[/img]
top of headlight assembly is on the bottom of pic
@harvey avatar
@harvey avatar
I haven't noticed that on my '07. I've heard/read of blocking the headlight causing melted lens but..
I wonder if your voltage regulator is supplying an over voltage?
EDIt: Bagel mentioned melting reflectors on the 300 in 2011- I suppose you have to bite the bullet & replace (either stock or maybe a HID projector retrofit?)
@dibber avatar
GTS300ie Super
@dibber avatar
GTS300ie Super
Just maybe the reflectors are defective. Should be replaced for free, but sure that won't happen.
New reflector needed, thoroughly clean up the connector and only use the stock wattage bulbs.
Also check the regulator output...
[ Time: 0.0148s ][ Queries: 4 (0.0062s) ][ live ][ 318 ][ ThingOne ]
