@mjrally avatar
@mjrally avatar
So after writing up an email to a friend with known good stator values, I came up with the idea of starting a thread similar to the metal stainless trim serial numbers that was on here a while back. My idea is for people to add resistance values from various scoots until we have a library to go through. That way we can all look in the library if we're questioning a stator or wiring. Bonus points if you can add a picture of the stator.
So I'll start- Grounding point was a fan cover screw. The bike is not running. Just checking resistance values.
2005 Stella. 5 wire stator
G- 381 ohms
R- 107
W- 0.00
Black- 0.00
Blue- .005
1979 US P200 7 wire stator
G- 495 ohms
Red to CDI-128
W-00.2
Black- 00.5
Yellow - No continuity
Red to harness- No continuity
Purple- 00.5 ohms
@mjrally avatar
@mjrally avatar
1966 Sears Bluebadge
Ignition coil 460
Blue .2
Red .6
Black .1
Green .2
Engine shroud bolt was the grounding spot.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
cool idea! We can actually make a formal Wiki Entry that we can link to as well if desired
@mjrally avatar
@mjrally avatar
Just the ignition wires test on my 76 ET3.
Key turned to on, CDI disconnected. Digital multimeter set to resistance. Red probe to the wire, black probe to the ground\CDI mount.
White wire: .000 ohms
Red: 111.9 ohms
Green: 442 ohms
Green: no continuity (because the key is turned on)
@mjrally avatar
@mjrally avatar
Thanks to nightwolf0215 for the values. Stock 2005 PX150.
Key off, stator still in scoot. Stator disconnected from harness. Ground point fan shroud bolt.
white .3
red 112
green 505
green #2 .5
black .3
blue .8
⬆️    About 9 months elapsed    ⬇️
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Here's a 1980 US 100 Sport, 8 wire stator, in engine, all wires disconnected, (-) test lead clipped to shroud:
Wires out to CDI:
Green 524 ohms
Red 112 ohms
White -0-
Wires out to terminal:
Black -0-
Purple -0-
Green 524 ohms
Yellow no continuity
Red no continuity
(Y&R -0- to each other)
@mjrally avatar
@mjrally avatar
125 Primavera. US Spec
B 0.00 ohms
Y .69
R 0.00
G 0.00
Y .70
@mjrally avatar
@mjrally avatar
SIP Vape AC, static timing
Blue to black- .002
No continuity black to any other color
Brown to red- 480
Brown to white- 67
Red to white- 560
@charlieman22 avatar
Nedminder
Nedminder
Quality post.
Had not seen this before.
Nice work MJ
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Can anyone offer up some values for a PX non-battery stator? I have a new one on the way but I'd like to diagnose / repair anything on my current one and save it for future use. They're always fixable, right?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Px non battery stator (new)
Red 110 ohm
White 0.7
Green n/a no connect
Black 1
Blue 1.2
Grounded to stator plate
@mjrally avatar
@mjrally avatar
Thanks John!
@swiss1939 avatar
@swiss1939 avatar
SIP Stator for: Vespa 50 R/​Special/​SR/​SS/​90/​R/​100/​125/​PV/​ET3
WITH handlebar indicators.
https://www.sip-scootershop.com/en/product/stator-plate-sip_15077460?q=STATOR
This works on my Canadian V100 pre sport with bar end signals. Only difference is this stator requires bar end signal bulbs at 6v-10w instead of the stock bar end bulbs which are 6v-18w.
Red to Black wires (IGNITION/HT COIL): 0.3-0.4 ohms (flickers between the two)
Yellow to Black wires (BAR END SIGNALS): 0.5-0.6 ohms (flickers between the two)
Blue to Black wires (TAIL/BRAKE LIGHTS AND HORN): 1.1 ohms
Green to Black wires (HEADLIGHT AND HORN): 0.3-0.4 ohms (flickers between the two)
SIP Part no.: 15077460 for smallframe with bar end signals
⚠️ Last edited by swiss1939 on UTC; edited 1 time
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
What are you using to measure milli ohms? With values that low you really need a good milli ohm meter. I've seen readings that high just touching leads together. A 4 lead system helps cancel out errors when readings are that small. I use a Fluke 289 for a handheld meter and it is OK in the 200 - 300 milli ohm ranges you are in. A dedicated 4 wire setup is best for values that low.
@swiss1939 avatar
@swiss1939 avatar
https://www.harborfreight.com/electrical/electrician-s-tools/multimeters-testers/11-function-digital-multimeter-with-audible-continuity-61593.html
Set to the lowest setting 200ohm. I'm not exactly sure if that scale translates to 1:1 exact ohms on the whole number or if a decimal reading like 1.1 is a multiple of ohms or something like that. Might have just been bad notation on my part by just calling it 0.6 ohms.
@swiss1939 avatar
@swiss1939 avatar
Vespa V100 (pre sport) Stator with bar end signals (came off a Canadian V100):
Red to Black: 0.5-0.6 (flickers between the two)
Yellow to Black: 1.7-1.8 (flickers between the two)
Blue to Black: 0.9-1.0 (flickers between the two)
Green to Black: 0.3-0.4 (flickers between the two)
⬆️    About 4 years elapsed    ⬇️
Vespa P125XVespa Rally 200
Does anyone have any values for a px150 2017 touring stator (euro). This has different colour cables as you can see. Trying to determine if this is knackered before starting a new thread for the preferred solution.
@gummy8879 avatar
2009 Stella, 2001 Honda Helix
@gummy8879 avatar
Late Stella/LML (07-09) 5 wire stator with the standard style ignition pickup: (Tested to stator plate)
Ignition:
Green 479 ohms
White 0.1 ohms
Red 112.7 ohms
charging:
Blue: 0.6 ohms
Black: 0.1 ohms
[ Time: 0.0171s ][ Queries: 4 (0.0094s) ][ live ][ 343 ][ ThingOne ]
