Hi guys lots of posts on protection from the dreaded rust what do you use?
Is there a spray on wax or some other bodywork protection?i,m thinking primarily about the underside as paint looks a little thin on my px
thanks
george
Is there a spray on wax or some other bodywork protection?i,m thinking primarily about the underside as paint looks a little thin on my px thanks george |
RIP
T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
bodgemaster
Posts: 7194 Location: So Cal |
Another fan of ACF-50, get the aerosol version for ease of use, spray everywhere but not near the brakes, then wipe excess off after 20 mins or so. It creeps into crevices you didn't know you had!
Greggy wrote: Another fan of ACF-50, get the aerosol version for ease of use, spray everywhere but not near the brakes, then wipe excess off after 20 mins or so. It creeps into crevices you didn't know you had! |
Posts: 2381 Location: Ohio |
108 wrote: Greggy wrote: Another fan of ACF-50, get the aerosol version for ease of use, spray everywhere but not near the brakes, then wipe excess off after 20 mins or so. It creeps into crevices you didn't know you had! Read up on it, watch youtubes on applying acf50 to motorcycles. O.S. |
1978 MotoVespa 160GT, 2009 LML Star 2T (Stella), 1961 Lambretta S2
Posts: 439 Location: Belgium |
I've used ACF50 in the past, but found it a bit difficult and messy to use. The same people make Corrosion Block grease, which has the same properties as ACF50, but is much easier to apply and stays where you want it:
http://www.acf-50.co.uk/corrosion_block.htm |
OldSchooot wrote: 108 wrote: Greggy wrote: Another fan of ACF-50, get the aerosol version for ease of use, spray everywhere but not near the brakes, then wipe excess off after 20 mins or so. It creeps into crevices you didn't know you had! Read up on it, watch youtubes on applying acf50 to motorcycles. O.S. It seems that most anti corrosion and inhibitors all seem to have the same properties. Lubricating, water repelling, but greasy and comes off fairly easily... wanted to see if ACF was a similar story. I have some ordered and will give it a try |
norman wrote: I've used ACF50 in the past, but found it a bit difficult and messy to use. The same people make Corrosion Block grease, which has the same properties as ACF50, but is much easier to apply and stays where you want it: http://www.acf-50.co.uk/corrosion_block.htm Would be great to try out corrosion block especially if it's easier to apply |
Johnny Two Tone
Posts: 8889 Location: San Diego, CA |
bodgemaster
ACF50 might be good for cracks and crevices, but it requires constant reapplication on exposed parts. It did nothing to keep my steel exhaust from rusting.
PX210 Polini, SIP Road 2
Posts: 63 Location: Isle of Axholme |
Dinitrol products are the best I,v used, I,v used their Rig coat and cavity wax on 3 different GTS's, none showed signs of rust, my P200e will be getting a dose shortly.
