@rhyde avatar
gts300ie
@rhyde avatar
gts300ie
Hi all
just wanted to ask if any one has made a solution to the light that seaps through the headlight with a jettin peak on their scoot
it really is a bit bothersome at night
thanks all
@theknights20 avatar
Vespa s 125 ie 4t
Vespa s 125 ie 4t
That would be annoying,
Maybe a bit of black tape on the Inside edge? Maybe some form a really thin mirror strip that would reflect the light back where it's intended to go?
Seems like a pain nether the less!
Ivana Tinkle has one on her GTS - no gap or light leakage, it snugs right up.
@syd avatar
@syd avatar
Try this:
Available at some stores only :)
@web-tech avatar
@web-tech avatar
Syd wrote:
Try this:
NO!
Use a Latex caulk that can easily be removed, Not a roof caulk
Even better get DAP Peel Away Caulk.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Tape or weatherstrip around the inner lip.
Don't goop any caulk on your scoot. It's not a bathroom fixture. It won't work and will look terrible. You'll regret it.
@web-tech avatar
@web-tech avatar
A nice thin bead of the peel away caulk on the inside would be fine and it just peels off with you finger.
@rhyde avatar
gts300ie
@rhyde avatar
gts300ie
yeh im a bit concerned about applying a caulk or goop thing to be honest
i may try a black tape thing or something, as it needs to be black
@davidcha avatar
2011 GTS 300 Super
@davidcha avatar
2011 GTS 300 Super
Oh, you can get the caulk in black...
http://youtu.be/tiPkYt09awo
Clown emoticon
Vespa s 125 ie 4t
Vespa s 125 ie 4t
Make sure you use a heat resistant tape that will also not react with the paint(rare for a reaction but possible!). The headlight gets very hot and id hate for it to melt. Standard electric tape may work for a while untill it eventually peels.
[ Time: 0.0133s ][ Queries: 4 (0.0056s) ][ live ][ 318 ][ ThingOne ]
