@darqmommy avatar
Lizard Brain
2007 GTS 250, "Vorga"
Lizard Brain
@darqmommy avatar
So... from my previous posts you may be aware that I do NOT patronize my local Vespa dealers. I bought Ms. Eldritch from a private citizen and I have no need to maintain a warranty. Also, the dealerships are quite far away and I want the convenience of riding Eldritch to the shop myself.
I chose a local shop that services mostly Chinese scoots, but whose owner is confident enough in his skills to take on a Vespa (with the bench manual supplied, of course).
First, the parts I bought from ScooterWest:
1.Variator overhaul kit (belt, rollers, sliders, nut)
2. Brake pads
3. Titanium spark plug (sounds high-end, no?)
4. Assorted extra bits in case
5. Canister filter
Second, the service highlights:
All service instructions per the manual
Replace variator parts
Brake job
Remove/check clutch bell (it was fine)
Remove/exorcise a dirt dauber nest that was built into an outside oil line (like, what is that even?!)
Remove engine to replace spark plug
The total cost for everything was like, $280.
That's pretty good, right?
⚠️ Last edited by darqmommy on UTC; edited 1 time
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
Maybe but I had everything other than brakes done except the brakes but rear tire and bushing (not including price of tire shipped directly from Motorcycle Superstore to dealer)installed for $280 at my last regular Vespa service before Vespa Houston changed ownership.
GTS 250
GTS 250
"Remove engine to replace spark plug?" What model do you have?
S 150 - it's in her profile...
Now own a Moto Guzzi Cali 1400. Wife has a Buddy 125
I can just picture the design team selling that design to the head honchos...
"Just think of the killing we'll make in increased service billing!"
I was wondering why you had the belt, rollers, and plug changed out at 3750 miles or 6000km. Seems a little early, but it's our money of course. And for what you got done, I think you did ok. Mechanics have to eat too. A side note: if you tilt the engine up, you can get to the plug. But with a titanium in there, you should not have to worry about changing it for a long, long time.
@darqmommy avatar
Lizard Brain
Lizard Brain
@darqmommy avatar
Sorry for the confusion.
I don't do KM well.
My ODO read 6,100 miles when I brought it in.
Also it's a 2009, so I wanted to be safe from any concerns about dry rot. At 60 mph, I don't want anything disintegrating on moi.
After my scare on the way home from the beach, I found it hard to fully trust Ms. Eldritch, and that was crampin' my style. Now I'm carefree again. Totes worth the $280.
I don't do KM well.
You might consider editing the title of your first post to reflect this.
@darqmommy avatar
Lizard Brain
Lizard Brain
@darqmommy avatar
FINE I WILL THEN
@mr_f avatar
2013 BV350
@mr_f avatar
2013 BV350
service price
Darqmommy,
I'd say that was a darn good price. I, too, use a non Vespa shop for any big problems. It is within walking distance from home and has been servicing Italian cars, bikes, and scooters for only about 50 years. Belts, rollers, oil and filters I do myself.
Also, Km.s are easy; it 's about half a mile!
Mr. F
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
KMs are hard for us "standard" retro 'mericans....
I always remember that 100kph is 62 mph
And a 5k run is 3.1 miles.
Run with that and you can do a lot of conversions in your head.
I drive to Canada regularly, and I finally have a car (my daughter's car) that will change from MPH to KPH with a button on the dashboard. Very convenient when you have a 70kph speed limit on side roads.
2012 Vespa GTS 300 Super
I performed my own 6,000 mile service on my unnamed 2012 GTS 300.
I bought the kit as well from Scooter West and followed Robot's excellent video.
I replaced coolant.
Replaced engine oil and filter.
New belt, rollers
Cleaned clutch case (air/wipe)
Cleaned/regreased airfilter
Changed rear tire
I'll eventually get to the spark plug..
I feel that someone with even basic skills can follow him along and know the work was done correctly. You really should learn. Then again, it does require an investment in tools and having space like a garage.
If Scooter West happens to read this, can you please send me a private message with instructions as to how to send Robot a gift certificate for a few beers from me to express my ongoing thanks to both him and to SW? Thank you!
@nautiker avatar
'14 Piaggio BV 350
@nautiker avatar
'14 Piaggio BV 350
My local Piaggio/Vespa shop won't install parts from anywhere else, unless it's something they can't get. They said they'd give me a one-time exception to install the Scooterwest belt & rollers for $50, since I was buying a couple of tires through them (the shop)... I wish I had a local/independent shop nearby...
@web-tech avatar
@web-tech avatar
Look on craigslist under motorcycles for sale, see if anyone is advertising for scooter repair.
@wleuthold avatar
@wleuthold avatar
It is great that you tackled all of that yourself. After years of having a great mechanic to do my work, he is moving soon so I am learning to do it myself.
darqmommy, $280 is about right for the work you had done. No problem there. I doubt they removed the engine but just had to tilt it. You have to disconnect a few pipes and bits, and the suspension to do this. It's not hard though and you could do it too.
@darqmommy avatar
Lizard Brain
Lizard Brain
@darqmommy avatar
I think I speak for a lot of people when I say this: for my peace of mind, whizzing down the highway at 60 miles per hour, I want the confidence that a seasoned mechanic has done it "right."
I don't doubt that I could learn to wrench, had I the tools or space. Right now I have neither, and it's not killing me. That's what mechanics are for.
What's important to me is getting back on the road in a timely manner, not drinking brewskies and sorting out itty bitty metal findings that could have a life-or-death impact on me.
Not to be defensive, but women are expected to have it all, and to be it all.
I categorically reject that notion because I know my limits.
I will not be doing major work on my scooter. If you like, I could instead:
Bake a loaf of bread
Create handmade jewelry
Describe in detail the NC 1915 (c) Medicaid Waiver
Continue rearing my children
Continue being the primary breadwinner for my family
Sing you the Soprano part of a variety of classical choral compositions
Ride my scooter with a smile on my face
After all, we cannot be experts at everything.
@web-tech avatar
@web-tech avatar
darqmommy wrote:
[b][i]I think I speak for a lot of people when I say this: for my peace of mind, whizzing down the highway at 60 miles per hour, I want the confidence that a seasoned mechanic has done it "right."
In most shops you have the kid just out of high school working on them with no training.
When I got a job as a motorcycle mechanic, I was applying to be a boat mechanic but they didn't have any opening and asked if I wanted to work on motorcycles as I had experience working on my own Hired me that day
@darqmommy avatar
Lizard Brain
Lizard Brain
@darqmommy avatar
Hmm, sounds dodgy.
I don't find that to be true at all. My mechanic was the shop owner. I had a discussion with him beforehand.
Am I missing something here?
I think it perfectly reasonable to expect and get good work from a professional.
Folks who want to get their brick foundations laid properly ask a 40-year master mason, like my dad.
Building houses is a big deal.
Hurling down the road at speed: again, a big deal.
At least, I think so.
Vespa GTS Super ABS
Vespa GTS Super ABS
The only shop I have been to is ScooterWest. They don't look or seem like they are just out of high school? I am trying to do all my own service work because 1) I have the tools, 2) The dealer is 30 miles away (in traffic), and I enjoy when/if I get it right myself. I wouldn't even consider trying to:
@madison_sully avatar
Similar for me but my job was assembling new bicycles. 16 years old I was, and by the end of the summer I was put in charge of all of the new bike assemblers. But, I was trained, and I will say pretty well (or at least it took well).
@dooglas avatar
@dooglas avatar
My dealer is a small Vespa/Piaggio shop with a two person service department. All work on my bikes has been done by the service manager, who has attended quite a few Piaggio training workshops. His assistant has less training but mostly does clean up and prep work.
Some shops are better than others and you certainly need to know the skill levels of the people working on your ride. It is not a given, however, that they are bozos.
@trotter avatar
Roughhouse Sport. Buddy 150(sold)
@trotter avatar
I'll take a loaf of bread, some handmade jewelry, and any cash you can spare, darqmommy.
@raputtak avatar
@raputtak avatar
As they say in Nowth Carlarna:
"Well, bless your heart"
@kshansen avatar
GTV300 (wife's)
@kshansen avatar
GTV300 (wife's)
Well if you send that scooter up to Central NY with a couple loaves of homemade bread in the pet carrier and do some reading up on Medicare for me I'll be glad to do the basic service work on it!
@mmehren avatar
'08 GTS (75k+ miles)
@mmehren avatar
deprived...
I feel like I'm missing out on excitement and adventure that other forum members get to experience. It's rough having Motorsport (Scooterwest) just down the road
Don't knock kids. I have found a place that will work on my Vespa. The owner is knowledgeable and this college kid Aaron is too. I saw him looking up stuff on YouTube. Nothing wrong with that. They charge $25 a hr for labor. Can't beat that either
@kshansen avatar
GTV300 (wife's)
@kshansen avatar
GTV300 (wife's)
Yes most of us were kids once! It almost scares me to think of some of the stuff people, parents included, let me work on when I was a teenager!
[ Time: 0.0173s ][ Queries: 3 (0.0026s) ][ live ][ 318 ][ ThingOne ]
