Vespa P200, Primavera 130, VNA200, Italjet Pack-a-Way Moped, Ciao etc
Posts: 322 Location: Humboldt County, California |
I toasted my ally Polini 210. I have,a stock top end and GS brand piston to get the bike running till i can afford to get a new kit. Will the MMW head for the Polini 210 work with the stock cylinder? If i have a good squish?
Posts: 4861 Location: Australa, Mate |
I use a Polini 177, & have used LML, Polini, MMW, & now a Parmakit heads all on the same kit, so suspect it will work
Posts: 2004 Location: UK (South East) |
Just wondering why you bought the MMW head. The Polini head for the 210 ally kit looks good with the additional cooling fins on the underside. What was the reason for not using it?
The MMW head may work as a stop gap, but it will be a mis-match in terms of bore, squish clearance and profile. The stock piston (GS in your case) has quite a pronounced crown, which may be very different to the Polini piston that the MMW head was profiled for. Some kits use almost flat top pistons but I've not seen the Polini. You may be better off getting hold of a stock 200 head which are very easy to come by. |
Posts: 8791 Location: Victoria, Australia |
Standard bore is 66.5 vs. Polini 69mm. So as Swa45 points out, you'll be mis-matched in that there will be combustion happening beyond the edge of the piston above the cylinder deck. Compression will be down because the head will have a greater volume than you need. But if you do it, let us know what happens!
Thanks for talking me down guys. I wasn't thinking of the bore size and squish being outside the stock bore diameter.
SWA45- The Polini Ally kit I got didn't come with a head, hence the MMW head profiled for that kit. I see thta POlini now has both versions with and without. Not sure if they did when I got it. I do have a stock head (a few). But it is a USA 200 head, so low compression (to meet emissions laws in the US in the 80s). That's what I was trying to avoid. |
Moderibbit
Posts: 8891 Location: Atlanta, GA |
I dunno, the USA head is probably better on the stock cylinder than some crazy thing with the wrong size machining
primavera130 wrote: I do have a stock head (a few). But it is a USA 200 head, so low compression (to meet emissions laws in the US in the 80s). That's what I was trying to avoid. + + = |
Moderibbit
xantufrog wrote: I'd that the only difference, ginch? |
