Is it possible to change the speedometer from the old 2014 GTS150 model to 2015 GTS model which similar to the Sprint?
Vespa LX190ie - kymco jockey SR 150
the speedo fitting might be similar but the speedo sensor is totally different. gts150 use wire but the new model use magnetic sensor.. you might able to change it but need heavy modification on electrical system
Thanks Timmy..
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
You can open up the speedo you have and paint/modify it to your own taste.
[ Time: 0.0113s ][ Queries: 3 (0.0030s) ][ live ][ 317 ][ ThingOne ]
