@pommy_paul avatar
nifty 50,Honda Dio,tgb,piaggio zip,Vmoto Monza,LX50,GT200l,PX200
@pommy_paul avatar
Anyone know what battery I have to buy for the clock on an LX50 guys?
Energiser 386 or equivalent. It's not that common, but I managed to find one in Bunnings.
https://www.af1racing.com/store/Scripts/prodView.asp?idproduct=57130
http://www.energizer.com/specialty-batteries/386-battery
@pommy_paul avatar
@pommy_paul avatar
Thank you
@pommy_paul avatar
@pommy_paul avatar
Would I be right in guessing behind the clear plastic? It doesn't seem to want to pull out?
There's the plastic bung that just pulls out, then plastic washer you quarter turn to get out, then metal spring washer, then battery.
https://modernvespa.com/forum/post1991101#1991101
@tonelar avatar
Formula 125
@tonelar avatar
Formula 125
My ET2 took a
Eveready/ Energizer 186.
Is the LX50 different? For some reason I thought they were the same as each other.
@pommy_paul avatar
@pommy_paul avatar
Lol quick run to local cheap shop bought a 4 pack none of them work,guess a trip to the auto shop tomorrow
tonelar wrote:
My ET2 took a
Wikipedia says 186 = 386
https://en.wikipedia.org/wiki/List_of_battery_sizes
@pommy_paul avatar
@pommy_paul avatar
Ok thinking out loud here,does the speedo need plugging back into bike before clock will come on? Or should it come on soon as battery is fitted?
Should come on right away.
Quick Google shows these are all equivalent:
SR43
AG12/SG12
LR43
L1142
186/301/386
6135-99-547-0573 (NSN)(S)
VINNIC
Size is 11.6 × 4.2mm
@tonelar avatar
Formula 125
@tonelar avatar
Formula 125
for all four to be bad sounds off... sure you're putting the batt in + side out?
As soon as the battery is fitted AND touching it's connectors. Once you get the two part (spring then cover) lid it should already be touching the - and + points. Then there's the semi clear plastic plug that covers the hole, but that just seals out moisture, dust, etc
Here's an image from another MV thread;
⚠️ Last edited by tonelar on UTC; edited 2 times
@vespergeezer avatar
GTS300, Cosa LX200
GTS300, Cosa LX200
The metal sprung washer is easily lost! A magnetic tool could be handy here.
But should work ok without if it goes AWOL. Mine's ok without one.
@tonelar avatar
Formula 125
@tonelar avatar
Formula 125
It just gives the battery a push, you could also substitute a fibre washer if you get it right side up and your connections aren't solid.
Mine just died. Crying or Very sad emoticon 8 yrs it lasted. Pretty good considering. Not looking forward to replacing it. On the fence about replacing the battery. However i do use it when i have appts. We'll see. Good luck.
[ Time: 0.0164s ][ Queries: 4 (0.0055s) ][ live ][ 318 ][ ThingOne ]
