@keepitfoolish avatar
Vespa 30th anniversary 125
When riding my Vespa 125 px my back wheel at certain times feels a little wobbly but i have had it looked at and its solid but its annoying as i feel its gonna come off at some point......Any advice ?????
@mjrally avatar
@mjrally avatar
Have you checked the tire pressure? What's the status of your rims and hub? Make sure those are straight and torqued to spec.
When the garage looked at it the stated that's how vespa's are and the wobble is normal , my tyre pressure is good just feels like at any moment it could snap
@mjrally avatar
@mjrally avatar
Got a friend with a similar scoot so you can do a side by side comparison? Unless you find another garage or tear into it yourself were just guessing.
Yeah gonna take it to another garage cheers though
@joep avatar
05 PX, 80P200, 63Li150, to many others
@joep avatar
sounds like your hub bearing is going out. Your rear tire shouldn't have any wobble. Check and make sure the hub nut is tight too.
@slohound avatar
GS150, Struzzo, Rally, PX
@slohound avatar
My rally was very wobbly, especially around corners. I realized it was the swingarm bushes so I replaced them and it rode like a whole new scooter.
@pdxjim avatar
2005 PX150 In a Part-time Relationship with a 2-Stroke Vespa Since 2007
@pdxjim avatar
What kind of tires do you have? If they're old-school block treads and you happen to fall in line for a short while on some kind of lengthwise groove or crack, the tread might momentarily "track" in the crack and it'll feel randomly wobbly, much like riding over a bridge with a grate surface, except this can come and go, depending on how crappy the pavement is. It freaked me out the first time it happened to me, until I noticed it only occurred when I happened to briefly ride down a crack or groove in the pavement, and like you, I found the back end solid as a rock so was puzzled at first.
Or, it could be mechanical as other's have mentioned.
@trumpyscooter avatar
Black 2007 PX200, Dark green 1986 PX225 Pinasco, "1972"(yeah rite) Tangerine px200, several TRIUMPH TIGRESS SCOOTERS
this
@danyouhandleit avatar
1967 Gran Turismo 1963 Lambretta S3 TV175 1971 Rally 180
TrumpyScooter wrote:
this
That would be my next move too.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
three
take it to chisselspeed or psn
px200
px200
Hello
What tyres have you got.
Grumpy
@patrick_hubble avatar
1964 Sears Allstate, 1979 P200E, 1980 100 Sport
Be sure and check that your hub nut is nice and tight and that the cotter pin is present and in place! (obviously check tire pressure and finally bearings might be the last item to check).
[ Time: 0.0102s ][ Queries: 3 (0.0042s) ][ live ][ 318 ][ ThingOne ]
