Hi there, I've got a strange problem. Bought a scooter in an auction. ECU/MIU/Throttle body was missing and ignition lock damaged. I bought and fitted new ECU+lock set, coded ECU to brown key and bike starts.
But it starts when applying one of the brake levers- not the start button. First I thought its something simple, but after checking all things it doesn't look like it. I checked brake switches, kill switch, start button, starter relay. They all work as it should. All the wiring looks new-it doesn't look like somone has tampered with it
Also I've downloaded workshop manual for 2008 GTS 300 Super- should be similar. There is a section with a simplified starting circuit diagram- looks simple: power is going through the ignition switch to fuse to either brake switch and through start switch to starter relay to ECU. Yes, one of the starter relay wires going to ECU unlike older bikes. I measured voltages between switches and components with ignition off, ignition on and when brake applied and I get strange readings:
1.There is continuity between brake switch and start button. But with ignition on 12V on start button and no Voltage on brake switch. With ignition on there is 5V to other side of the start button wire.
2.There is continuity between one of the wires from start button to starter relay with ignition on and not pressing starter button.
3.Also when i start the bike there is no voltage present on one side of the starter relay
So to sum up : I am completely confused- can someone steer me to the right direction. Thanks!
