I've been trying to sort out electrical issues on a 6 volt (no battery) 1965 VBB that I completely rewired. Everything electrical on the scooter is new.
I have a question about the horn. Seems like it should be one of the simplest circuits to figure out on the scooter but my horn won't toot.
I disconnected the green wires at the junction block and tested the green wire for continuity between the junction block and the handlebar switch and between the switch and the horn. I have continuity.
Next - with the green wires still disconnected at the junction block and with the engine running I checked the voltage between the green wire from the stator and the engine case. No voltage registered on my multimeter. Was my technique a valid test procedure for the green wire? Is there another procedure I should try to figure out why the horn won't work?
