I recently got my 2010 Piaggio Mp3 400 back from the 10.000 km service.
After reading the overwhelmingly positive feedback here regarding the Dr Pulley variator weight upgrade, I decided to replace the OEM rollers for the 17 grams.
I am however less than impressed. Before, I comfortably cruised around 100 kph @ 5400 RPM. Now with 17 g:s, the same speed gives me close to 7000 RPM. Quite a turn for the worse, I think (although, maybe not totally unexpected). The low end shuddering, choppiness and noise improved and the engine feels a bit more responsive overall, but I am also afraid that I am putting it under to much pressure with this "upgrade". It feels and sounds like it is straining more.
I also fear, from reading other posts here, that my mechanic might have put the weights in wrong somehow, even though I gave him pictured instructions and he said he had done this before. My mechanic also claimed that the Dr Pulley variator sliding pieces (ordered together with the weights) did not fit and he had to use stock sliding pieces. The mechanic, by the way, did not inspire too much confidence overall, but didn´t strike me as grossly incompetent either.
My questions are:
1. Could the fact my mechanic did not get the sliding pieces to fit be indicative of incorrectly installed weights? I have read on this forum that the sliding pieces are not as trustworthy as the weights, although I find it a bit weird they didn´t fit.
2. Is 100 kph @ 7000 RPM really normal for correctly installed 17 g:s? What RPM:s are normal, and how much worse is this for the engine, wear wise? Thinking about changing to 18 grams actually, to keep the smoother takeoff but reduce engine wear - but if nobody else is getting these high numbers on 17 grams, I want to check if they are installed properly first.
Any feedback appreciated!
