@lozjm avatar
2016 Sprint 50
@lozjm avatar
2016 Sprint 50
Just stopped
Kick won't budge
Back wheel will freely spin
Start gives nothing
Dead
Sad
@mjrally avatar
@mjrally avatar
Get home safely and open up your belt cover. Belt could have snapped and jammed.
@lozjm avatar
2016 Sprint 50
@lozjm avatar
2016 Sprint 50
Ok recovery guy managed to free up kick, and suggests it's Seized
Need to get it to shop tomorrow
Says it's normal a head rebuild ? 500 euros ?
Sad
Probably less than half that. It's a common top end, and about three hours to do it. There are plenty of good aftermarket cylinder kits out there that are going to be a lot cheaper than getting one from the local Piaggio dealer. I don't know what it costs to rebore a cylinder in your part of the world, but in the US it's almost always cheaper to buy a new cylinder kit for a little two stroke. Typically you will replace the cylinder, piston, rings and wristpin. Any competent scooter mechanic can do this job.
Check to make sure the oil pump is pumping. That's often what makes them seize.
Now's a good time to think about putting a 70cc kit on it.
@mjrally avatar
@mjrally avatar
What kind of symptoms does it have now that the kick starters free? Everything spin but weak compression? Still seized?
Have you checked the CVT system yet? By all means check the top end, but why not see if it's something as easy as a broken belt that's jammed up the variator and starter teeth. This same situation happened to me back when I first started riding and the back tire spinning freely with no resistance was the smoking gun for a broken belt with the variator and weights jamming things.
@thenaughtylemur avatar
2006 Suzuki S40 - 1978 Puch Pinto (sold) - 2006 Piaggio BV250 (R.I.P.)
When you say back tire spinning freely, what exactly do you mean by that?
@web-tech avatar
@web-tech avatar
Put it on the center stand and see if you can spin the rear tire. Might just be a broken belt locked everything up.
@lozjm avatar
2016 Sprint 50
@lozjm avatar
2016 Sprint 50
So my baby is home !
She wasn't Seized
Seems the transmission cover inspection hole plug had come off, some debris had got in and smashed the variatior fan
This then shredded the belt
So new belt and fan , and while they were at it relplaced my leaking feul tap that was causing my overnight flooding as it was not requiring a vacuum to work !
Whew emoticon Glad you found the reason. I was going to suggest Prune Juice. Good for humans when we get seized. Razz emoticon Laughing emoticon When the belts snap it rains all kind of hell in there. Not get out there and ride.
@mjrally avatar
@mjrally avatar
Good deal. Have fun riding
[ Time: 0.0126s ][ Queries: 4 (0.0063s) ][ live ][ 339 ][ ThingOne ]
